Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 02-13-2014, 04:05 PM
Copenhagen Angel's Avatar
Copenhagen Angel Copenhagen Angel is offline
Vehicle: 1999 Dodge Ram 1500
Copenhagen Angel is on a distinguished road
Question Receiver Wiring Kit Installation?
I just bought a new 7 Blade and 4 Flat Multi-Tow Hopkins wiring kit for my 1999 Dodge Ram 1500. The one that came with my truck is not the right plug in for my horse trailer. Does anyone know or have the wiring diagram for the wires pre-existing on my truck? I tried all data and found nothing. Does anyone know the color code for the wires in my truck? Is this the right kit? I got it from Advanced Auto Parts and they said it is but it has a 4 flat connector that is suppose to connect the Right Turn signal, Left turn signal, and tail lights. does my truck have a place to plug that into already or am i going to have to cut off the connector and just connect its wires to my truck wires? any help is appreciated!!
Old 02-14-2014, 12:59 AM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
I assume have a 6 pin connector on the truck.. either way doesn't matter... pull the socket the truck out, usually removes with couple of screws or a nut on the back side. One you can get to the connector, just unscrew the terminals for each color witch matches your flat pin.
Old 02-14-2014, 10:23 AM
the colors already match?
Old 02-14-2014, 12:52 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If you have a trailer sales or rental facility in your area you can get an exact match wiring harness for around $25.00.
It plugs directly into the factory plug where each taillight is connected and removes cutting and or splicing the original wiring on the truck.
It looks like this:
It's an in-line plug on each side. Unplug the trucks taillight, plug the harness in, plug the taillight back into the harness.
To answer your question, no I'd have to pull my taillights to check the colors.
Old 02-14-2014, 08:08 PM
ok thanks, that looks good I'll probably see if I can get that. Thanks guys!
Old 02-16-2014, 04:46 PM
Vehicle: 95
Rep:1776
Let us know how it works out. I've hard wired a few vehicles in the past with a probe light to check for current/operation, but this kit makes it a 5 minute job.
Old 02-17-2014, 12:28 PM
Well I'm horse broke right now so i cant afford the wiring harness to plug into my tail lights but I do have a testing light so ill probable just wire it to the existing wires, it will just take longer but I have access to a heated shop with lifts and every tool known to man kind so doing it the hard way wont be so bad.
Old 03-10-2014, 08:26 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
You used to be able to buy the adapter at Walmart or any auto parts store for like 5 bucks
"I don't care to hear what your ideas are, mine are better"
Old 03-15-2014, 12:04 PM
Color: Blue
Rep:95
stil can, just picked up a 7 way to 4 way for my new trailer yesterdday for 5.99 at wally world.
