2014 1500 payload - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 02-16-2014, 03:18 PM
Fireboy Fireboy is offline
Vehicle: 2017 ram 1500 4x4
Color: Maximum Steel
Rep:28
Fireboy is on a distinguished road
Originally Posted by TJC.geotech View Post
fireboy, commercial stickers and license come into play when the trailer is over 10000 pounds not the combined weight. And the opp do not carry scales. That's MOT's jurisdiction.
Trucks, trailers and converter dollies alone or in combination with a total gross weight, registered gross weight or manufacturer’s gross vehicle weight rating exceeding 4,500 kilograms (kg),
The above is the commercial sticker definition for ontario. See the word combined. Thanks for the correction but I didn't pull this out of my a$$. I have the commercial sticker and fully understand the law.
Also my brother is an OPP officer and he has scales in his car. He can weigh a vehicle and call for MTO if weights are exceeded. Also did not pull that out if my a$$.
Old 02-16-2014, 03:54 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
Default 2014 1500 payload
Yes the key word in that being "commercial". As in vehicles being used for commercial purposes. Pulling your camper or boat to the cottage is not commercial and you do not need any special permitting or license until it exceeds 10,000 lbs.
Old 02-16-2014, 04:03 PM
Rep:28
I never said camper or boat. A utility trailer full of dirt will put you over. That is not commercial is it? I am posting useful info that is accurate. Not here to debate with you. You are right if that's what you need to hear.
Old 02-16-2014, 04:15 PM
Color: Granite
Rep:114
Originally Posted by Fireboy View Post
. A utility trailer full of dirt will put you over. .
No, I'm sorry it will not. Even a double axle unit loaded until it's tires are ready to pop will not put you over 10K.
Once you go over 10K on a "privately" owned trailer, you will need a non-commercial Class A. Which has it's own restrictions, and is not a full Class A.
Personally, I have had my commercial license for 28 years. Class AZ.
These are Canadian rules by the way, if I have the American members scratching their heads.
Old 02-16-2014, 04:17 PM
Color: Granite
Rep:114
And this is why we have this peculiar market in Canada for utility trailers with a Registered gross weight of 9,999 pounds. You don't see that anywhere else.
Old 02-16-2014, 08:06 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
The question to start this was about payloads, not how much you can put on a trailer before you get pulled over. The GVWR minus the actual weight of the vehicle is how much you can carry. Again, this has nothing to do with pulling a trailer.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 02-16-2014, 08:12 PM
Rep:23
Ya don't go by the door sticker that gives you the exact payload you have left on your exact truck. Warning labels on medications are just a guideline too. The sticker tells you your exact payload. It's not a guess. FYI. I live near Toronto and the OPP carry portable 4 corner scales now. They are cracking down on overweight vehicles. If your truck and trailer exceed or have the capacity to exceed 4500kg or roughly 10 000lbs you need a commercial sticker on truck and trailer. So towing a 3200lb plus trailer means you need commercial stickers. Almost every trailer that can hold dirt would put you in the commercial sticker range. Most people have no clue about these weight restrictions and sticker requirements and that is why they are cracking down on it now.
You are assuming nothing has been added to the vehicle since it left the factory. Anything that has been added lowers the payload. Aftermarket wheels and tires can add considerable weigh, bumpers, winches, covers, and many other things. If i put the amount stated for the payload in the back of my truck I would be about 500 pounds over the gross weight rating of my truck.
Old 02-16-2014, 08:50 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Just moved back from Ontario last summer, don't recall reading on MOT's website stating I needed "commercial" plated vehicles to haul topsoil or gravel or anything of the sort if the trailer weight was under "10,000lbs", that's the compliant weight that shifts the category I believe as others have stated.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE/ CARLI ADJUSTABLE TRACKBAR
Old 02-16-2014, 09:01 PM
PTCTreeGuy PTCTreeGuy is offline
Trim Level: Outdoorsman
Color: True Blue with Black
Rep:39
PTCTreeGuy is on a distinguished road
How about those that are so pedantic about every little ounce JUST READ THE DOOR CARD? Go to a lot and check out a range of trucks with options and see what the payload is listed at.
Arguing who is smarter at thinking they 'know' the law adds absolutely nothing to it so either list an actual law, not my brother, boss, manual, etc claims or SHUT UP. It doesn't really matter what the law says about being over when the question is what the ACTUAL payload would be.
Old 02-16-2014, 10:21 PM
ahill37's Avatar
ahill37 ahill37 is offline
Vehicle: 2014 Ram
Trim Level: Bighorn
Rep:19
ahill37 is on a distinguished road
Not sure if this applies to Canada or not but in the US the door sticker is the law. Where I work at we up-fit vehicles, tool boxes, lift gates, service bodies etc We have to change out the sticker on new vehicles with a new one printed that represents the new payload. For example if the vehicle has a 1700lb payload and we add 400lbs of equipment we have to install a new sticker that now reads a gross payload of 1300lbs. We have upfitted trucks with a CC that were only left with about 600lbs of payload left once all the equipment was installed.
IMO if the door sticker on your new truck shows 1700lbs it's a reflection of the equipment that is installed on your truck. More options = less payload.
3 Ram/Dodges, 1 Jeep, 2 Chevy's, I'm sure my wife believes me when I say I need all of them
