Old 02-14-2014, 10:16 PM
BlackonRed12 BlackonRed12 is offline
Vehicle: 2012 Dodge Ram 1500
BlackonRed12 is on a distinguished road
Default Help tapping into reverse light for backup camera
I am installing a new reverse camera, and tapped into drivers side reverse light. Red wire to truck white and red, and black to black. camera came on for one moment but will do nothing now. Could i have tapped into wrong wire?
Old 02-14-2014, 10:29 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Check your connections.
Is this the OEM camera or an aftermarket camera?
Chrome... in moderation.
Old 02-14-2014, 10:59 PM
Ater market
Old 02-14-2014, 11:14 PM
RogerRamJet's Avatar
RogerRamJet RogerRamJet is online now
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Does your reverse light still work? Check the specs on the aftermarket camera and see what voltage and amperage it takes to operate.
Old 02-15-2014, 07:04 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
You might try connecting the wire for the camera to the 7 pin trailer connector. The center pin is backup lights for a trailer.
Mods: Too many to list
Old 02-16-2014, 04:43 PM
How would i tie into that?
Old 02-16-2014, 04:55 PM
Didn't work. It seems the camera just isn't getting the power it needs.
Old 02-17-2014, 10:14 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
The reverse pin on the 7 pin trailer plug has more than enough power to run the camera. I would check to see if you have power to the camera and check the ground wire also.
You may have a bad camera.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 02-17-2014, 10:59 AM
I plugged the camera straight into my wall and it worked fine, but when i switch it back over to mt truck I get nothing.
Old 02-17-2014, 11:37 AM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
The reverse light wires wont work ..
you need to use the trailer pins. look under the truck and remove some of the black tape. In the wires find the orange/white wire(its the center of the 7 pin ). thats the 12 volt hot reverse wire. then for ground I like to just use a ring fitting and go right to the frame from one of the bolts back there. you can use the reverse light ground wire or the thick black wire in the trailer plug.
