Truck is running hot with no heat - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-15-2014, 11:08 AM
Ramology Ramology is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: SLT Laramie
Color: Red/Silver
Ramology is on a distinguished road
Default Truck is running hot with no heat
I have a 97 Ram 1509 5.9 and I replaced radiator, water pump, hoses, thermostat, thermostat housing, and fluids but it still runs hot with no heat. What could it be?
Old 02-15-2014, 11:24 AM
farf02's Avatar
farf02 farf02 is offline
Vehicle: 2014 Ram 1500 Quad Sport
farf02 is on a distinguished road
Two choices in my book,
you either have a hell of an air block, or head gaskets!
farf02's Avatar
Or plugged heater core
Old 02-15-2014, 11:55 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
is it possible the thermostat is in backwards?
Old 02-15-2014, 12:05 PM
rcmpvet's Avatar
rcmpvet rcmpvet is offline
Vehicle: 2014 Ram
Color: Black Gold Pearlcoat
Rep:51
rcmpvet will become famous soon enough
The quickest way to find out and to possibly correct the problem is to park your truck on an incline, front end high, take off the radiator cap and start your engine. Watch for it to start to heat up and bubbling in the radiator.
What you are doing is allowing the coolant to circulate yet also providing an escape for an air block, any air in the system will eventually rise up and escape. Once you see the coolant circulating and allow it to do so for a bit then just top it off with just enough coolant to close up the air gap at the top.
If that does not work then you have to look at other problems.
There Is No Such Thing As A Stupid Question: HOWEVER: Search Function is Your Friend
Old 02-16-2014, 12:10 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'm siding with Primo on this one. I've seen a LOT of bad thermostats, new out of the box.
It's always a good practice to drop the thermostat into a pot of slightly simmering water to check it before installing it.
Always make sure the pointed end points at the radiator.
Check the bottom hose for excess pressure after it warms up by trying to squeeze it.
If you do follow the advise to let it run with the cap off on an incline...be very cautious of the engine reaching temperature and the coolant spewing out of the radiator.
Old 02-21-2014, 10:46 PM
Lazarus Truck Lazarus Truck is offline
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Agree with others. Cant trust stuff just cause its new. Always check stat. Don't even like re-built pumps because sometimes they use the wrong impeller. But truck hot, AND no heat? Agree with air first.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 05-02-2014, 01:37 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Parking the truck on an incline to bleed the air is not really effective. If you want a better method, drill 2 small holes on the thermostat housing.
Old 05-14-2014, 06:48 PM
B-ran
I'm having similar issue... Kinda... I'm lost I know that. My truck only overheats when hot outside. Heater core in n out hose both hot but no heater. Have flushed, new water pump, even took out thermostat. Why is it overheating? Fan belt driven. No leaks, oh yeah... Gurgling in heater core when push gas pedal (air in system)
Old 05-14-2014, 08:10 PM
pontiacdude's Avatar
pontiacdude pontiacdude is offline
Vehicle: 2016 Ram 1500 CC
Trim Level: Bighorn
Color: black forest green pearl
Rep:17
pontiacdude is on a distinguished road
just replied to another one of these. more times than you think its a bad intake gasket. ive chased down the problem before ending with bad intake gasket
