Old 02-15-2014, 06:36 PM
tommyb6273 tommyb6273 is offline
Vehicle: 1997 ram 1500 4x4
tommyb6273 is on a distinguished road
Default need some wiring help
I have a 97 ram 1500 with 5.9l
im installing an air/fuel gauge
I need to know the location and color of the o2 signal wire.
the instructions say it needs to be installed before the o2 connector. im looking for the closest location maybe at the pcm.
also what wire at the headlight switch is the dash lights?
Thanks
Tom
Old 02-16-2014, 01:13 PM
come on guys this is supposed to be the best ram site, but two different posts and cant even get a reply!!!
Old 02-21-2014, 11:15 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
I have a Ram 97 FSM. I would be happy to get you that info this weekend. Do you mean the up-stream, or down-stream O2?
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 03-10-2014, 09:59 PM
PartsGuysRamSST PartsGuysRamSST is offline
Vehicle: 1998 Dodge Ram SS/T
Trim Level: SS/T
PartsGuysRamSST is on a distinguished road
Default Re
Do you still need help i can get a pcm pin out and wiring info let me know
Old 03-11-2014, 01:07 AM
major324's Avatar
major324 major324 is offline
Vehicle: 1997 dodge Ram 1500 2WD 5.9
Trim Level: sport
major324 is on a distinguished road
Default meter wiring
use a voltmeter and test for a wire that has variable voltage when running , its pretty low and it should bounce around. don't tap into the constant voltage that is for the heater and supply voltage. . I ran mine under my door sill plate with a grommet and over the tranny and then tapped into my headlight switch for lighting. its night time here in cali but will look at wire colors and get back.
