allison transmission swap? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Old 02-16-2014, 02:47 AM
Tgresch Tgresch is offline
Vehicle: 1995 Dodge Ram
Tgresch is on a distinguished road
Default allison transmission swap?
well im putting some more power in my truck for now its just a cold air intake less restrictive exhaust and a jet performance stage 2 chip (may possibly doing a throttle body spacer (i got the thing for free so it cant hurt to try) and a 180 thermostat and will be doing headers and dual straight pipe with an X-pipe soon) and eventually porting and polishing the heads with new roller rockers new cam and some cupped pistons with slightly longer rods or a larger crank and although the truck came with the 46rh with the extra power i want a more reliable that has a much higher torque rating which is where the allison falls in. has anyone heard of an allison swap into a 1995 5.9 gas engine truck and if so where?
Old 02-16-2014, 12:08 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
I'd be inclined to talk to some of the guys that build transmissions for the Cummins trucks. See what handles the tq of a Cummins. Find out what is the weak link of the 46 RH. It may just mean raising the line pressure. The 545RFE'S are pretty stout, but converting the truck to run the TCM could be a nightmare. Your mods aren't very aggressive . Perhaps the guys at SharaDon could give you an idea, or maybe they have a valve body up grade. I just run a Sonnax line pressure booster on my 545RFE and spray a 100 shot on a cammed , modded hemi, probably 425rwhp and have never had an issue. Making an Allison fit and work would be a hell of a challenge.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-23-2014, 01:20 PM
glcarter's Avatar
glcarter glcarter is offline
Vehicle: 2011 Ram 2500
Rep:59
glcarter will become famous soon enough
I have an uncle that had an Allison put behind his 2500 V10 4 wheel drive at Fountain Transmission in Iowa City, Iowa. He has over 200,000 miles on it now with no issues. States he even picked up 2 mpg.
Just picking brains, mine's worn out!
Old 02-23-2014, 10:45 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
Find a pre-electronic A-518. This is basically a 727 small block trans with an OD unit on the back of it. They're fairly stout stock (and it's a bolt in).
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
Old 03-05-2014, 12:00 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
You can build your 46rh to last for cheaper than swapping in an Allison which is not as good as the Chevy camp would lead you to believe.
This is assuming you're talking about a modern Allison. If you're talking about an old one out of a medium duty truck, they are strong but so so so power hungry.
Silence! Differing opinions will not tolerated
Old 03-05-2014, 12:01 PM
Rep:130
Isn't that what he has?
46rh Is a 518 essentially
Old 03-06-2014, 04:48 PM
Rep:300
If I remember right, the 46RH is a 518 derivative, maybe with more electronics? I know the later versions you couldn't just wire up a 2 pole switch to engage the OD.
"Big Red"
