Laramie Longhorn Ecodiesel Tow Capacity - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 02-16-2014, 05:51 PM
ElRushmo ElRushmo is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Longhorn
ElRushmo is on a distinguished road
Default Laramie Longhorn Ecodiesel Tow Capacity
Hey guys,
I was wondering how much a longhorn ecodiesel can tow. I saw 6700 pounds, but that seemed like misinformation. Does anyone have any info on this?
Thanks!
Old 02-16-2014, 05:57 PM
Ramzaq's Avatar
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:276
Ramzaq is a jewel in the roughRamzaq is a jewel in the roughRamzaq is a jewel in the rough
With the 3.92 rear I think it was around 9,000 to 9,500 lbs, a little less than the Hemi.
Old 02-16-2014, 06:04 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2006 Chevrolet Avalanche
Color: Bronze Alloy Metallic
Rep:2035
A Laramie Longhorn Ram with the EcoDiesel 4x4 Crew Cab with the 6.4 bed can tow 8,350.
Check out anything more with any of the models here.
Chrome... in moderation.
Old 02-16-2014, 06:39 PM
Thank you!
Old 02-16-2014, 10:44 PM
Blackhawk13's Avatar
Blackhawk13 Blackhawk13 is offline
Vehicle: 2014 Ram 1500 Longhorn CC 4X4
Color: Maximum Steel Metallic
Rep:36
Blackhawk13 is on a distinguished road
Yeah Arth is correct. It's quite a bit less than the HEMI similarly equipped in Arth's example.
His ED would tow 8,350 and the HEMI version would tow 9,750 (1400lbs more).
Current: 2014 Ram 1500 Laramie Longhorn 4X4 CC 6'4"
Current: 2011 Jeep Grand Cherokee Overland 4X4
Past: 2009 Dodge Ram 1500 Laramie RWD CC 5'7"
Past: 2009 Infiniti G37S RWD
Past: 2008 Honda Accord EX-L Coupe
Past: 2006 Mazda 3S GT Sedan
Past: 2002 Dodge Dakota SLT+ 4X4 QC (SEMA TRUCK)
Past: 2001 Pontiac Bonneville SSEi
Past: 2000 Pontiac Grand Am GT1 Sedan
Old 02-19-2014, 01:53 PM
I went to that ram site and it says that the max tow capacity without payload is 7,400 pounds. I was looking into getting a trailer that was 4,700 pounds dry (23 feet). Would this be a good idea or should I look for a lighter trailer? Thanks guys, I really appreciate the help!
Old 02-19-2014, 02:12 PM
Rep:2954
Your question could be answered better by the type of trailer
Old 02-19-2014, 02:24 PM
finn5033's Avatar
finn5033 finn5033 is offline
Vehicle: 2013 Ram 1500 cc 4x4
Rep:32
finn5033 is on a distinguished road
Not sure where you saw that but that is wrong. Arth has the correct numberof 8,350. My crew cab outdoorsman with the pentastar V6 has 7,150 tow rating, so I would certainly thing the ecodiesel can pull more than a couple hundred pounds more than that
Old 02-19-2014, 02:30 PM
Finn, I used the ram website that was posted earlier in the thread. Your answer sounds more correct though. I am assuming that their site is incorrect as well because that seems like way too low of a tow capacity.
GT, here is the trailer...
http://www.rvtrader.com/listing/2011...mytrader=true&
Old 02-20-2014, 03:45 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
the diesel and that trailer would be fine. the most you'd likely load the trailer would be 2000lbs, with avg load of 1000lbs so yourmtrailer is looking to be around 5700-6700lbs, tongue weight would be 700-750 lbs at most, question would come down to payload availability and weight of passengers.
on another note the trailer had a lot of black streaking, I would give the roof a once over and make sure its still good.
