Old 02-16-2014, 09:47 PM
iridelow's Avatar
iridelow iridelow is offline
Vehicle: 2014 Ram/Hemi
Trim Level: Reg. cab Express
Color: blue
iridelow is on a distinguished road
Default Need help replacing gauge bulbs please..
I have an 04 ram and the gas gauge bulb is out. Also, can't see my gauges where the a/c, fan and temp controls are at, guess those bulbs are out as well. Anyone have a video or instructions how to remove what I need to replace these on a 04 ram? thanks. Also, what bulbs do I need?
Old 02-17-2014, 09:55 AM
hotkarl's Avatar
hotkarl hotkarl is offline
Vehicle: 2002 Dodge Ram SLT QC 4X4
Color: Silver, PB2
hotkarl is on a distinguished road
X2 for the gas gauge bulb.
2011 Ram Big Horn...RIP(thanks to Hurricane Sandy)
PS2 Bright silver, Hemi Quad cab, 3:92's, most of the other bells and whistles.
1998 Dodge Durango 5.2 4X4...The family truckster!
Old 02-17-2014, 10:44 AM
PappaJohnRam's Avatar
PappaJohnRam PappaJohnRam is offline
Vehicle: 2003 Ram 1500
Rep:563
PappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to all
This should help on bulb selection ... http://ramforumz.com/showthread.php?t=90315
Pappa John
Old 02-20-2014, 07:48 AM
iridelow's Avatar
Color: blue
Anyone????Someone must know how to do this, I'm sure it's pretty straight forward.
Old 02-20-2014, 08:20 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1049
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
For the HVAC controls there will be one phillips screw in the bag holder that is molded into your interior under your radio, once you remove that screw that entire piece just pulls off and give you access to the back of the hvac panel to change the lights.
For the Gauge cluster, this one is a little more challenging, the panel right in front off your knees simply pulls down out of the way then while you have the aforementioned hvac piece off there will be screws that hold the trim that goes around the cluster starting from the right side of the steering wheel all the way around to the left side of the steering wheel, once you get all the screw removed you have to pop all of the surrounding trim out and then the cluster has 4 screws that hold it in. once those are clear you will be able to pull the cluster out, there are 3 wire looms that plug in and are a bitch to reach and unplug from the back of the gauges once you get them unplugged you can try and carefully position the cluster in a way which it will come out, you have to have your head tilted just right, then all the lights are right on the back of the board. if you have a set of torx screwdrivers it does make it easier to remove the first black cover from the cluster on the backside as it allows you to get to the lights much easier
Old 02-24-2014, 07:55 AM
iridelow's Avatar
Color: blue
Thank you very much. That's what I was looking for....
Old 02-24-2014, 08:09 AM
Kamanhart's Avatar
Rep:1049
If you run into any issues when you are doing it and need some help you can pm me and i will try to help you out best i can bud, good luck
Old 02-24-2014, 07:27 PM
Keystone.45 Keystone.45 is offline
Keystone.45 is on a distinguished road
Here's a youtube vid:
http://youtu.be/uV-4-9aIgB0
In case the link doesn't work, the title of the video is
Gauge cluster removal for a 06 Dodge Ram"
Old 02-27-2014, 09:45 AM
JAWS37 JAWS37 is offline
Vehicle: 2004 Dodge Ram 2500 CTD
JAWS37 is on a distinguished road
My bulb is out on my HVAC controls. I use the light from my phone to let me know where my knobs are pointing.
Thanks
