Old 02-18-2014, 03:55 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:184
Default diff fluid
Im going to be changing the diff fluid in my 09 ram 1500. How much do i need to use and what kind is best to use.
Old 02-18-2014, 08:26 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Check your owner's manual, but my 05 took ATF+ 4. I'd use the Mopar, its premium synthetic. I changed mine at 150,000 miles and it still looked pretty good. I think 1 qt was enough, but check your manual. Good time to change power steering fluid, so pick up 2 qts.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-19-2014, 05:22 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
since your 2009 has a lsd differential, dont forget to put the lsd additive in also, its required
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 02-20-2014, 08:53 PM
WVU RAM WVU RAM is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT Big Horn
Color: Stone White
Rep:15
WVU RAM is on a distinguished road
I have been researching this topic myself for past 6 weeks. Overall majority recommends amsoil severe gear oil while mentioning that Lsd additive is not required because amsoil and others( royal purple Lucas) already have required additive. Bob is the oil guy.com is good reference--they love amsoil for gear oil over there. My other concern is dropping rear diff pan. Lots of people recommend just having fluid removed by pump and just replace fluid while others strictly say drop pan clean and replace original or aftermarket cover with rtv sealant. What is going to be your approach?
Old 02-24-2014, 07:43 PM
bstc00's Avatar
Color: Inferno Red
Rep:184
I was looking at replacing the pan with a mag-hytec cover and using royal purple as i have some laying around. I do 130 miles a day in towing and would like the extra fluid.
Old 03-20-2014, 02:26 PM
seppie10 seppie10 is offline
Vehicle: 2010 Dodge Ram 1500 Trx4
Trim Level: TRX4
Color: INFERNO RED/GRAY
Rep:19
seppie10 is on a distinguished road
I would just jack up by the hitch maybe a few inches so you can get to all the bolts on cover and start wrenching them out start at the bottom and when you get to the top just loose one and keep it in there and all the rest come out and then pry the cover from bottom out and let it drain into your pan. Then when its done dripping take that last bolt out and cover off and brake clean and wipe clean and scrap off the left over gasket goo on cover and the rear itself. Then when all clean use your black magic RTV sealant and go around the center of the lip of the cover and around all the bolt holes with your RTV and then match it back up to your rear and start a couple of the bolts so it is snug. Install the rest of your bolts to snug tightness and let it sit for an hr and then tighten them up and add your desired oil. Fill to your whole and your done. It takes 2 hrs the way I just told you just because of the RTV drying time. Good luck and I have done a lot this way and not one issue. You also get to see your gears make sure everything is running the way It suppose to. happy wrenching
seppie
Old 03-20-2014, 09:58 PM
82corvette's Avatar
82corvette 82corvette is offline
Vehicle: 2012 Ram Crew Rambox
Trim Level: Laramie SLT
Rep:128
82corvette will become famous soon enough82corvette will become famous soon enough
I'm confused, did Chrysler actually use atf in their differentials?
