Old 02-16-2014, 06:25 PM
sgreen3's Avatar
sgreen3 sgreen3 is offline
Rep:24
sgreen3 is on a distinguished road
Default Electric Fan Upgrade?
Ive been thinking of swapping in an electric fan in my Ram. My question is for the guys thats done this would I be able to use just a single universal 16" or should I go with a dual setup. I would think either one of those 16s or maybe a dual set-up would do fine. You can get the universal fans for very reasonable money so seems like it would be a cheap upgrade?
1997 R2500 4x4 5-speed 5.9L
Old 02-21-2014, 11:19 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Don't bother. Unless you are doing some wild-ass upgrade, or swap, the stock cooling will be fine. The rad/fan set-up in these Rams is seldom a problem, even for major upgrades in the engine.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 02-22-2014, 05:19 PM
sgreen3's Avatar
Rep:24
Yea that's kinda what I figured. Seems like it would be more trouble than its worth.
Old 03-04-2014, 12:28 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Its not that factory clutch fan setups are problematic, but the electric fans take off parasitic drag from the engine.
If you do decide to run one, go with a Taurus or Mark VIII fan. They pull much more CFM than the cheap 16" fans and you can find em at a junk yard for cheap.
Old 03-05-2014, 01:31 PM
soco native's Avatar
soco native soco native is offline
Vehicle: 02 ram 1500 5.9
Trim Level: slt sport package
Color: BLACK
soco native is on a distinguished road
The 2000 model jeep grand cherokee fan is a plug and play option too, I'm doin one with a fan shroud kit from Chris at PIE. I
TWIN TURBO IN THE WORKS!!!
Built for boost short block by PIE, forged internals, PIE by JE blower pistons, Edlebrock MAX port heads, PIE turbo cam, Comp Turbos, JGS waste gate and BOV, SCT tuned by PIE and DIY 304 SS sch30 pipe turbo manifolds.
Old 03-06-2014, 04:14 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
I had so many problems trying to put an electric fan on my 01. First off I tried one 16'' fan and it wasnt enough, then I did 2 16'' fans and it still was not enough. Those 5.9s take a lot of air to cool them down!
Old 03-06-2014, 04:53 PM
sgreen3's Avatar
Rep:24
Yea Ryan that's what Ive been hearing. I think Im just going to leave it how it is. I just like a clean engine compartment, but a properly cooling engine is a lot better, LOL
Old 03-11-2014, 02:11 AM
major324's Avatar
major324 major324 is offline
Vehicle: 1997 dodge Ram 1500 2WD 5.9
major324 is on a distinguished road
cmon the fan delete on the dyno is worth the over 10 hp and quiet and MPG!!! it is worth it. I did a setup off ebay that uses dual 16 in spal fans with a spal PWM controller but derale makes a controller that is real nice from summit for cheaper . but yes it is worth it! it stays at 190 all the time even with a/c on and hot California days. had it on there for over 2 years now and the only thing I changes is my temp sensor at 4.99
Old 03-17-2014, 11:18 AM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
I also believe in changing over to an electric fan due to the gains you can get. The only thing that is holding me up is a shroud to accommodate the windshield washer tank, radiator overflow tank and the electric fan. And I’m sure there are other tanks that can replace the ome but I haven’t looked hard enough yet. I know there is at least one aftermarket shroud out there that will work but I want it to look more professional. Even consider making my own aluminum shroud.
Old 03-19-2014, 12:14 AM
Rep:194
As I said before, unless you have some "wild-ass" cooling need, stock will be fine. It is DESIGNED for towing, its a TRUCK! Just because you put a few electric fans behind it, don't mean it will flow better. The SHAPE of the fan shroud is just as important to air-flow. I've been a hot-rodder, and racer for 30+ years, and seen people create cooling problems where there were none by thinking that more-was-better, but not understanding how it actually works. Electric fans are not FREE power. They must be powered, and that is by increased drag on the alternator. JMHO.
