Did I screw up?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-20-2014, 06:35 PM
bluebird29 bluebird29 is offline
Vehicle: 2007 Dodge Ram
Color: Blue
Rep:29
bluebird29 is on a distinguished road
Default Did I screw up??
2007 SLT with 73,000. I changed the transmission filters and fluid. I did not drain the torque converter just what was in the pan. The fluid that was in there looked as good as the ATF+4 that I placed back. Now it seems to be slipping. Iv noticed when its changing in the last gears it shutters and also whe I start it and place in reverse it takes a second to catch in gear. WTH do I do now guys. I really need some advise!!!! How can simply replacing filters and fluid make this happen??
Old 02-20-2014, 06:38 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Sounds to me like there could be an air pocket some where in the system or not enough fluid. When you topped up the fluid did you check the level with it running and in gear? If not you'll be low on fluid.
Old 02-20-2014, 07:03 PM
chrisnarron chrisnarron is offline
Vehicle: 2009 dodge ram 1500
Color: gray
Rep:59
chrisnarron will become famous soon enough
Did you use mopar filters? I know it should not make a problem but I jave heard it does several times
Old 02-21-2014, 08:31 AM
Color: Blue
Rep:29
I checked the level with it in normal running temp and in neutral and it is showing full.
I used what filter set is sold at Auto Zone and not OEM filters.
Old 02-22-2014, 09:41 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
have you checked the fluid again since you have been driving it? it is best to check after a drive cycle where every gear has been shifted into
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 02-23-2014, 01:44 PM
Color: gray
Rep:59
I would redo it with mopar filters
