Old 02-20-2014, 11:48 PM
dubaholic2 dubaholic2 is offline
Vehicle: 2006 Dodge Ram 1500 Big Horn
Rep:18
dubaholic2 is on a distinguished road
Default Replaced fan clutch, now it's loud
When I was having the rear diff noise checked a few days ago we were sitting with the truck idling while we were discussing the rear diff noise and the "check gauges" light came on, and we found that the temp gauge was almost to red hot. Shut it off, popped the hood and found that the fan clutch was shot (not locking up). Went to Autozone that afternoon and bought a new one and replaced it, no biggie. The thing is that now when I start the truck and when you're over about 2k rpm, it's got a ton of engine noise. It goes away at times, but there is no rhyme or reason to when it makes noise. It always does it when cold, but will go away shortly, but then the noise will come back sometimes when your cruising and give it throttle. At first I questioned if I had put the fan on backwards, but I checked that and it's correct. Has anyone else run into this? The temp is within spec, but the noise really bothers me. Any insight is appreciated. Thanks, Ian
Old 02-23-2014, 03:13 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Ian, I think what you're hearing is the fan pulling a ton of air through the radiator. You weren't used to it before because the fan clutch was weak or wasn't working at all. Now that you have a new fan clutch, it's pulling air which can be quite loud.
Old 02-24-2014, 02:10 AM
mastertech10 mastertech10 is offline
Vehicle: 2013 RAM 1500
Rep:12
mastertech10 is on a distinguished road
Its actually because you used a aftermarket clutch. I have noticed a difference between the OE and aftermarket clutch hubs I have installed for customers.
Old 02-24-2014, 09:59 PM
Rep:18
I got wise and decided to check it when it was cool and found that the clutch wasn't disengaging. I got another clutch and swapped it again and now it's acting pretty much like it should. Still a little loud at start-up, but the noise goes away pretty quickly now. Thanks for the input.
Old 02-25-2014, 01:18 PM
God Bless Texas!
Rep:2929
Voonderbar! Thanks for the update!
Old 05-25-2014, 09:36 PM
Lon Lon is offline
Vehicle: 2007 2500 Megacab 4X4 5.9 C
Color: Light khaki metallic pearl
Lon is on a distinguished road
hi , yes it is normal for you to get a ton of noise at startup then quiet down shortly after, then when it gets up to normal op temp it cycles especially if you hit it for a bit then back off
