Old 02-21-2014, 10:39 PM
ACLakey ACLakey is offline
Vehicle: 2006 Dodge Ram 1500
ACLakey is on a distinguished road
Default 2006 Ram 1500 Front locker
I am pulling together funds to swap my stock 3.55 gears for 4.56 in my 2006 Ram 1500. I am currently running 285/70R17 (32") but will likely be putting 285/75R17 (34") on this fall. I am likely going to put a truetrack in the rear at the same time. I have a few questions.
1) how are the stock traclock lsd units? I found a used one that is rebuilt for a really good price.
2) Does my truck have the Chrysler 8in IFS front housing?
3) what Limited Slip units are available for the front?
Thanks for the info.
Old 02-24-2014, 02:02 AM
mountie816's Avatar
mountie816 mountie816 is offline
Vehicle: 2015 Power Wagon
Trim Level: Power Wagon
mountie816 is on a distinguished road
If one is available go with the Detroit True Trac. An excellent limited slip and no clutches to wear out. All gears.
2015 Power Wagon, Black/red decals. Rambox.
Old 02-24-2014, 10:24 AM
glcarter's Avatar
glcarter glcarter is offline
Vehicle: 2011 Ram 2500
Rep:59
glcarter will become famous soon enough
As far as I know, there is nothing available for the IFS as far as I know. Think I have heard you will have to replace the front carrier just to swap gears. Something about the carrier is welded to the ring gear I believe. Then if you do get the limited slip/locker in the front it would make steering a bitch as the axles would be locked together all the time unless you can find something like and electric or air locker.
Would almost be better to scrap the whole IFS and put a solid axle in it. But, that opens a whole new can of worms!
Just picking brains, mine's worn out!
Old 02-25-2014, 02:08 AM
mountie816's Avatar
Steering wouldn't be a problem with a limited slip but a locker would make it interesting at high speed. Too bad ARB doesn't have one.
