lunge at startup - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-23-2014, 08:11 PM
Bill2010Hemi Bill2010Hemi is offline
Vehicle: 2010 Dodge Ram 4x4 QC
Bill2010Hemi is on a distinguished road
Default lunge at startup
Hello, can anyone tell me why my 2010 ram lunges forward momentarily in cold weather when I start it?
Old 02-23-2014, 09:47 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
It lunges forward while it's in park?
Old 02-24-2014, 09:30 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:501
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
I presume you mean it lunges forward once you put it in Drive. This is usually associated with torque converter drainback. Typical cause is a bad spin-on filter in the transmission. Did you recently have the transmission serviced (filters replaced)?
Step 1 would be to check the fluid level. If OK, then next step would be to drop the trans oil pan and check both filters. Look for a loose (or completely fallen out) spin-on filter, or a main sump (flat) filter that is cracked at the base of the plastic snout, split open along the side seam, or has the plastic snout dislodged from (or not pushed up through) the seal in the pump housing. If everything looks OK, then replace the spin-on filter with a Mopar filter (current filter likely has a bad anti-drainback diaphragm in it).
Old 02-24-2014, 09:55 AM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:166
Or you can wait until your RPM drop below 1000... I have the same situation, but it only happens if I don't let the RPMs settle down after starting the truck.
S S H A D O W
Old 02-24-2014, 05:37 PM
Yes, while it is in park. On cold mornings (below freezing) I will open my door, start the truck without getting in and it will lunge forward...it doesn't take off or anything but it will rock the tires back and forth for a second.
Old 02-24-2014, 06:09 PM
Rep:2968
That's interesting. Know a good Catholic priest?
Maybe Mark (TransEngineer) will get back on and shed some of his brilliant insight and knowledge.
Old 02-25-2014, 09:33 AM
Vehicle: N/A
Rep:501
Well, who'da thunk it? (Not me, that's for sure)
I guess it won't actually go anywhere if it's in Park, but if it does jerk it could be due to clutch drag in Neutral due to the cold fluid. Or maybe you have a damaged UD clutch pack that is passing some torque even when released.
Will it drive forward when it's in Neutral (hot or cold)? If so, then you definitely have a damaged (or welded) UD clutch. Next time, try starting it in Neutral instead of Park (make sure you are INSIDE the truck!!) and see what happens. If it does start to move, is that only for an instant, or does it keep going?
Old 02-25-2014, 05:51 PM
No, it starts in Neutral but doesn't move at all, even when I give it gas. I will start it in neutral in the morning. It only did it on mornings when the outside temp was in single digits or low teens...lately it has been upper 20's lower 30's in the mornings and it hasn't done it. I doubt we get anymore temps that cold til next winter.
Old 02-26-2014, 07:40 AM
Started up in Neutral this morning..it lunged forward just enough to rock the tires back and forth and quit. Don't know the temp this morning but its pretty cold.
Old 02-26-2014, 08:57 AM
Vehicle: N/A
Rep:501
Well, trans fluid thickens as it gets colder, so I'm guessing the residual fluid in your clutch packs (in particular, the UD clutch) is causing some drag (even though the clutch is released) and therefore tries to move the truck. But as soon as things start spinning, the fluid in the clutch (which would be laying in a puddle in the bottom of the clutch retainer) gets spread out around the clutch, giving just a thin layer of fluid on the discs (rather than a solid slug of fluid completely filling up all the space between the discs), so the drag force disappears (or at least, drops off enough that it's unnoticeable).
So bottom line, I wouldn't worry about it.
