Supercharge the 09 Hemi? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-24-2014, 04:52 AM
OldSport's Avatar
OldSport OldSport is offline
Vehicle: 2009 Dodge Ram Sport
Trim Level: SLT Sport
OldSport is on a distinguished road
Lightbulb Supercharge the 09 Hemi?
Hey all. Been looking at possibly putting in a supercharger into the hemi now that warranty is all done. The two companies I have been looking at is RIPP and Procharger. I'm wondering if anyone has dared to do this as both claim their product is 'safe' to use with stock trans. Any thoughts?
Ram'in since 2010!
Old 02-24-2014, 01:58 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
I'd be more worried about getting it tuned properly so not to rattle the stock pistons. I spray a lot of nitrous and have no problem with stock 545RFE. I do run the Sonnax line pressure booster. I would talk to the guys at SharaDon for anything more to the transmission, check out their valve body upgrades. Talk to (hemifever) as far as tweaking the tune. I ran a Tacoma for 140,000 miles with an untuned motor, lucky, the hemis are tunable.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-24-2014, 11:15 PM
Rep:3347
Have a look at BlackHemiRam's and my builds. He uses the Ripp and I run a highly modified Procharger setup. Both of use have needed to upgrade our transmissions but he's also running the stage II RIPP, which is no longer available, and I'm pushing 600rwhp with my procharger. We are both running the L&M transmission, and so far it's holding up nicely behind mine and BRH's did burn out a clutch pack but he was also running it without Mike's tuning package since Mike's been fighting with RIPP as they lock their tunes.
Depending on where you are in AB, but you can look at Davenport to install/tune or do the install yourself and have Davenport or CCMR in Stony Plain do the fine tuning.
Old 03-19-2014, 10:06 PM
NolaRam's Avatar
NolaRam NolaRam is offline
Vehicle: 2009 Ram 1500 Crew Cab TRX
Trim Level: TRX
Color: Detonator Yellow
Rep:29
NolaRam is on a distinguished road
The magnuson isn't bad 6 lbs of boost with no boostapump. dyno tuned to about 400 rwhp, very modest 11.5 degrees of timing on stock bottom end. Could get more out of that if I wanted to add timing or lean it out a little more, but it is a daily driver. The 545 is rounding off a bit and probably needs some help at this point. never had any belt problems or engine problems. I am about to turn it into a 392, which means the tranny will definitely need some help as I pulley up the blower to make use of the new hard parts and cubes.
Old 04-27-2014, 02:48 PM
OldSport's Avatar
Thanks for the info guys. While looking into it, I now have transmission issues. So that idea is a back burner at this point. Transmission is stuck in 4th. Throwing a solenoid code. I have started another thread on this issue. I hope its not that big of an issue, but if it is, I was quoted $8700 for a new from factory transmission. Ouch haha.
Ram'in since 2010!
Old 04-27-2014, 04:21 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Mike at L&M Customs charges $2500 for a boost proof built 545RFE
(+$500 if you prefer to keep your trans and buy a core from him)
I pushing 500WHP, Ripp Stage III Vortech V3, 8psi boost at 5800rpm
Spraying water/meth that's triggered when Boost hits about 4psi
to help keep my pistons happy
Racing it in 4WD 4-Auto on Four 28" Mickey Thompson Drag Radials, ATS Triple Lok 3000 stall torque converter...
There's at least 3 of us in Edmonton running virtually the same setup.
even on my heavy street set (305/50R20 Terra Grapplers on stock 20's)
I'm rippin shit up BAD!, destroying muscle cars at will with 4WD Full throttle launch
Damn near in the 3's 0-60
Click my sig pic for a link to my build thread, or
a you can find LOT more posts in the 5.7L performance section on superchargers and transmissions:
Here's a few to get you started:
http://www.ramforumz.com/showthread.php?t=173840
http://www.ramforumz.com/showthread.php?t=153656
http://www.ramforumz.com/showthread.php?t=138456
Old 04-27-2014, 05:52 PM
OldSport's Avatar
Thanks BlackRamHemi. I will probably look into this now that my transmission is on the fritz! You have a nice setup from the sounds of it. Looks real nice. Thanks for pointing me in the right direction. You as well CdnoilRAM. Appreciate the insight!
Ram'in since 2010!
Old 04-27-2014, 06:05 PM
Rep:3347
There is no need to buy a new transmission, especially for that price. The L&M option is a good starting point if you want to run boost in the future; you can have yours rebuilt; or you can buy a rebuilt one. My brother's '05 trans finally crapped out last week and he just picked up a rebuilt from Chrysler at cost since he works for them.
Old 08-04-2014, 11:48 PM
NolaRam's Avatar
Trim Level: TRX
Rep:29
what do they do the the l & m? add clutches, up the valve body pressure? the switch to second prime seems to the the weak link in these transmissions.
Old 08-05-2014, 12:16 AM
Rep:3347
Machine the carriers for more clutches, rework the valve body, up the line pressure, but the most important is the custom transmission tuning that he does for it, that's the real important stuff.
