Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-24-2014, 08:45 AM
jmw642 jmw642 is offline
Vehicle: 1994 dodge 4x4 2500
Color: green
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
jmw642 is on a distinguished road
Default no engine heat
1994 dodge 4x4 cummins. for so reason my heat never gets over 145 when its cold out 0 or close to it. Have installed new thermostats 4 times with no results. On this model there is a small hose that bypasses the thermostat would it help to close it off. not sure what its for anybody know?
Old 02-24-2014, 01:47 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
The bypass hose is for when the engine is cold. It keeps the coolant from going through the radiator when it doesn't need to be cooled. DO NOT close it off.
Where are you getting the 145 number from? The cluster temp gauge or are you using a temp gun/thermometer?
Old 02-24-2014, 09:12 PM
Color: green
Getting the temp from the gauge. It used to run in the 185 range. could it maybe be the radiator cap?
Old 02-25-2014, 12:14 PM
Rep:2929
I could be, but I doubt it. Usually a bad cap causes an overheating issue. I would suspect the sensor not sending enough volts to the gauge. Try and get an accurate reading from a thermo gun sensor or get the truck up to normal running temp and stick a thermometer in the radiator. Take extra care in taking the cap off. There shouldn't be any pressure, but just be careful.
Old 02-26-2014, 11:00 AM
Color: green
Yesterday the temp was 10 degrees out and checked the temp at the radiator was at 150. but was a little warmer out. From day one when I got the truck in 94 the temp would vary. Would work up to 180 then drop to right down to 140. It would continue doing that at all times. Talked to Dodge and was told they had a special thermostat for it so had that put in. Actually worked for 50 miles then back to where it was up and down. Have just been living with it sense. Guess I can live with it like this but would be nice to get more heat when its cold out. Here in Montana we do get a little cold weather.
Old 02-26-2014, 11:03 AM
Rep:2929
You think!?! And I complain when we hit the 20's for 1, maybe 2 weeks during our "winter" season.
Old 03-17-2014, 11:43 AM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
My truck runs at @140-150 degrees and I get plenty of heat inside the truck. But that’s here in the Midwest temps. And we just had a few days in the single digits. If you never change out your heater core, there’s a good chance it’s clogged up some. Just did mine a couple of weeks ago and now I have HEAT inside the cab. For the past 2 years I always had to run the blower on low speed in order to get any heat. My old heater core never leak so I never smell any antifreeze insie the cab.
Old 03-17-2014, 03:11 PM
Slitherbeast Slitherbeast is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Brilliant Black Pearl Clearcoat
Rep:18
Slitherbeast is on a distinguished road
deisel engine should run at 180* F min. to 210*F max. put on a winter front. close it up to acheive higher temps. diesels don't make much heat idling around or rolling down the highway empty.
