Old 11-30-2013, 10:20 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1123
Word. But if I missed it, others will too.
R.I.P. MOPAR BIG HORN (KYLE)
Old 12-02-2013, 05:24 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Nice write up guys. But I already knew most of the information from reading the countless threads you guys have posted this info in lol. Reps to you both!
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 12-02-2013, 05:27 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Thanks! And yes, as I mentioned in the intro most of the information has been written many different places throughout the forum. Just not altogether in one spot to go over everything. I'm hoping this eliminates the need for the threads asking questions about this stuff to be constantly showing up and people like myself, CHP, lowUFO or many others needing to repeat the same information over and over.
Old 12-02-2013, 06:13 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
I'm pretty certain you covered almost everything needed for everyone, just have to get people looking. I have put the link in my sig to hopefully help guide members to the right location.
IG:@briley59
Old 12-02-2013, 10:51 PM
Juiced Juiced is offline
Rep:33
Juiced is on a distinguished road
everything i was looking for in one simple easy to read thread.
Great job!!!
Old 12-26-2013, 01:11 PM
vortex911 vortex911 is offline
Vehicle: 2013 Ram 2500 Power Wagon
Rep:24
vortex911 is on a distinguished road
Would you use the same wheel and tire fitment guide for 2500 aplications? I have a 2013 PW (will be leveled) going to go with aftermarket wheels and tires. I dont want the tires to extend much past the factory fender flares. Fuel maverick rims 20" or 22" and either Nitto terra grapplers, Trail grapplers tires. what wheel tire combos would work to achieve this result.
Old 12-26-2013, 07:46 PM
Rep:2067
Yes and no.... As far as how far the tires will stick out, yes the numbers will be fairly similar. But because the suspension on a 2500 is way different there's way more clearance on the inside. So the inside clearance numbers don't apply. You can run more of a positive offset to keep the wheels tucked under the truck but still have room for wider tires.
If you want to stick fairly flush with the flares I'd look at 20 or 22x9 +12 offset or you could go with a 0 offset if you want to be out slightly past them. Check the thread HERE on Cummins Forum. It will give you a better idea of what different set ups look like on HD trucks. The specs will be pretty much the same on 3rd and 4th gens as far as inside clearance and outward poke is concerned.
Old 12-27-2013, 02:48 PM
mattl22's Avatar
mattl22 mattl22 is offline
Vehicle: 2011 Ram 1500 Sport QC
mattl22 is on a distinguished road
Have had my truck for almost 3 months now and looking to do my first mod. Thinking about doing the bilstein 5100s to level it off. Now, do I need to replace the rear with bilsteins as well? Not currently thinking about doing a lift, just the level. So can I run the bilsteins up front with a completely stock setup in the rear? Thanks in advance for any input.
Old 12-27-2013, 06:00 PM
Rep:2067
Yes you can install the Bilsteins in the front without doing anything to the rear. Replacing the rear shocks will only give you a slightly better ride, it won't do anything for the height.
Old 12-30-2013, 02:58 PM
mattl22's Avatar
Thanks! I assumed that would be the case but we all know what happens when you assume!
This will be getting done soon as the weather warms up here in Pittsburgh!
