Old 03-03-2014, 10:47 PM
Bequerman Bequerman is offline
Vehicle: 2014 ram 3500
Trim Level: Tradesman
Bequerman is on a distinguished road
I just went thru this last weekend, same issue, crappy grainy picture. Bought 2 rca cables and kept screwing with the ground. Nothing. Unhooked from tail light reverse wire and tapped in to a solid 12v wire, camera crystal clear. Just run a test jumper of solid 12v from battery to camera and u should see some results. Then u will know for sure.
I ended up tapping the reverse wire in the loom above rear axle on driver side frame. I have no idea why it wouldnt work from the tail light but worked perfect 3 feet forward in the loom!???? Let me know if you need pics or better explanation.
B
2014 ram 3500 fat bottom, 22.5 Alcoas on 35s
Old 03-05-2014, 11:59 AM
blackexpress13 blackexpress13 is offline
Vehicle: 2013 ram 1500
blackexpress13 is on a distinguished road
going to the trailer harness fixed my problems, thanks everybody
Old 04-17-2014, 07:53 PM
DJ17 DJ17 is offline
Vehicle: 2013 Dodge Ram
Color: Grey
DJ17 is on a distinguished road
Do you have a picture of how you wired it to the trailer harness?
