Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Rust Repair
Rust Repair Fighting Mother Nature!
Old 03-03-2014, 05:05 PM
rking6's Avatar
rking6 rking6 is offline
Vehicle: 2006 Dodge Ram 1500 Mega Cab
Rep:75
rking6 will become famous soon enough
Default Undercoating my Mega
These salty Ohio roads have caused the undercarriage in my 06 to get kind of ugly so I was thinking about undercoating it somehow. Wondering what kind of products are the best and what does a dealer use? Would Line-x or any other bedliner stuff work?
Zone 6" lift, 35x12.50 Toyo Open Country Mt, 20" XDs, Custom True Dual Super 10s, 5" MBRP Tips
Old 03-04-2014, 07:56 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I use something called (Fluid Film). Remove fender liners and try to find a car wash that has a bottom blast feature, run her thru 2 or 3 times. Get her on a lift if you can, or at least in a garage up on jack stands. Check above the braces that run fore and aft above rear wheels for trapped dirt, sand and salt, clean as well as you can, same with all holes in the frame. Remove all wheels including spare.Put garbage bags around disc brakes. Once everything is clean, spray or brush rust converter on all rust. The one that I use is CRC Rust Converter. Let it set a while, maybe a day for the converter to react and neutralize the rust, it will turn black. Then I spray a heavy coat of Fluid Film everywhere, especially the blind areas over rear tires, inside frame, inside doors. Try to repeat every year. If you do it yourself, you know it's done right.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 03-23-2014, 12:09 AM
Superduper Superduper is offline
Vehicle: 2013 Crew Cab
Superduper is on a distinguished road
My truck is already rusty. Damn deicers!
