new to me truck. help me figure out what's been done - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 03-10-2014, 01:13 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Originally Posted by NWRQC View Post
Funny you say that. I used mine all the time so adjusting to not having one after swapping the turbo out took a little bit. I use my brakes way more now.
Ya that's pretty much the main thing keeping the thought of swapping the turbo out of my head. I don't want to lose the factory exhaust brake. It just works so nicely and is awesome to have.
Originally Posted by kjg26 View Post
how can I test that it's working? I hear the air pump on occasion. I can see the rpms hold but u don't hear the exhaust brake noise I expect. nor do I significantly slow down.
It's not really an air pump sound... it's almost a whistle. When you're going down a hill and let off you should hear that slight whistle sound and it should be holding the truck back fairly well. Especially if the RPM's are higher (at least 2000 or more).
Old 03-10-2014, 03:09 PM
kjg26 kjg26 is offline
Vehicle: 2004 2500 Quad Cab Diesel
kjg26 is on a distinguished road
Default new to me truck. help me figure out what's been done
The BD exhaust brake has a air pump associated with it. I get absolutely no hold back. Although I'm not much above 2000 so maybe I will give that a go
Old 03-10-2014, 04:33 PM
Moderator
Rep:2140
An air pump?? Why would it need one of those? Can you snap some pictures of the whole set up on your truck so we see exactly what's going on and how it's all hooked up?
Old 03-10-2014, 04:36 PM
will do this evening.
Old 03-10-2014, 04:44 PM
if you go onto bd diesels website for a 2003-2004 turbo mount exhaust brake instructions it shows the mounting. it's mounted inside the fender. I don't have easy access to it.
Old 03-10-2014, 10:57 PM
Pictures of the exhaust brake
