Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 03-05-2014, 11:19 AM
RARMSTRO RARMSTRO is offline
Vehicle: 2015 Ram Big Horn
Color: Cherry Red
RARMSTRO is on a distinguished road
Default 2010 ram tranny's
Hello everyone, just wondering if anyone else has had the tranny cooling lines leaking on their ram 1500?
Old 03-05-2014, 06:06 PM
Nwdodge Nwdodge is offline
Vehicle: 2013
Trim Level: Chrome
Nwdodge is on a distinguished road
Very normal
Old 03-05-2014, 08:00 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:725
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
Leaking is normal? Neither mine nor my dad's 2009 Ram have tranny cooler lines that leak.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 03-06-2014, 09:55 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:478
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Where are they leaking? At one of the crimps / connections between metal lines and rubber hoses? At one of the threaded fittings at the end of the line? Through the side of the rubber hose? Through a metal line that is worn / damaged?
Old 03-06-2014, 02:12 PM
Color: Cherry Red
Looks like the rubber hose ends between the metal lines.
Old 03-06-2014, 02:28 PM
Vehicle: N/A
Rep:478
I would go to a shop that makes / sells hydraulic hoses (I think some parts stores do). They could probably make you up a new piece of rubber hose that would connect to the metal lines using compresion fittings, so you could basically cut out the old section (just use a mini tubing cutter to cut the metal line on each side) and then splice in the new piece. That might be cheaper / easier than trying to get a whole new set of replacement cooler lines.
Old 03-06-2014, 02:48 PM
Color: Cherry Red
I was thinking of buying jobber hoses but cannot find any, industrial hose shop may be the way to go, thanks.
Old 03-09-2014, 02:47 AM
jagr200 jagr200 is offline
Vehicle: 2010 Quad 1500 SLT 4x4
jagr200 is on a distinguished road
Who has really had this issue? I crawled under mine and didn't see a leak. But it was raining haha
Old 03-18-2014, 11:37 AM
Color: Cherry Red
I have talked to some local guys that have had this problem, it may be due to a very cold winter here.
Old 03-18-2014, 11:45 AM
Geniusgene's Avatar
Geniusgene Geniusgene is offline
Vehicle: 2010 Ram 1500 QC
Color: Inferno red pearl
Geniusgene is on a distinguished road
No issues on my my 5 speed with 28000 miles.
BT catch can, Borla pro xs, Afe drop in filter.
