Old 03-05-2014, 02:41 PM
Buellrider's Avatar
Buellrider Buellrider is offline
Vehicle: 2012 ram 1500 R/T
Trim Level: R/t
Color: Wht
Rep:145
Buellrider will become famous soon enoughBuellrider will become famous soon enough
Default Anyone with a mcgaughy 2/4 kit cut the springs to 3/5
How many coils had to be cut??
2012 R/T
Old 03-05-2014, 02:47 PM
chrisb38002's Avatar
chrisb38002 chrisb38002 is offline
Vehicle: 2013 Dodge Ram
Trim Level: R/T
Rep:86
chrisb38002 will become famous soon enough
I was asking the same question on another forum. So far I have been told to cut 1/4 from the front (bottom of spring) and 1/2 from the back (top of spring).
It will be interesting to see what replies you get here if they differ. I'm installing the same kit.
2013 White Ram R/T
Mods: BT Catch Can (red), Mufflex DOD24, S&B CAI, BakFlip VP Tonneau, McGaughy's 2/4 Deluxe, Spohn Adjustable Panhard, AirLift 1000, Hellwig Rear SB.
Old 03-05-2014, 03:17 PM
Buellrider's Avatar
Trim Level: R/t
Color: Wht
Rep:145
Cool thanx... I see a lot of 3/5's somebody has to know for sure.
2012 R/T
Old 03-06-2014, 03:41 PM
Buellrider's Avatar
Trim Level: R/t
Color: Wht
Rep:145
No one???
2012 R/T
Old 03-07-2014, 11:59 AM
Jizanthapus Jizanthapus is offline
Vehicle: 2014
Jizanthapus is on a distinguished road
With the Belltech 2/4 drop, people cut 1/2 a coil on the bottom of the front spring and a full coil on the top of the back to make a 3/5 drop.
Old 04-11-2014, 09:47 AM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Hemi HFE is on a distinguished road
theres no way 1/4 coil is gonna get a full 1",
typically its 3/4 - 1 coil for an inch..
this is a good question tho ..
I just installed the McG 2/4 'economy' kit and, on my light RC/SB V6,
only got 3" (if that) in the rear..
so I'm a gonna be trimming some coils !
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
Old 04-13-2014, 08:56 AM
Hornet Hornet is online now
Vehicle: 2013 RCSB Ram
Rep:470
One coil off the stock front springs equaled a 3" drop on my RCSB.
Ended up buying a new spring.
I made the mistake of listening to internet guru's,won't do that again,as a new spring is 170 bucks
I'd start with the reconmended 1/4 coil,you can always cut more if needed,but you can't add it back
Just an FYI guys,if you go much lower then 2" on a spring lowering in the front,you'll have a hard time getting the wheel alignment into spec,with-out going to the adjustable A-arms.
If you want lower then 2" on the front,you're better off doing the drop front spindle swap + a spring swap,that combo is wheel align-able.
Old 04-24-2014, 04:39 PM
Buell - you have an regular cab RC right ?
JETsimple reports for his '14 R/T :
"I removed exactly 1 coil from the top of the rear springs and got maybe 1/2" lower. I was hoping for a little more but it's OK for now."
{ thread at http://ramforumz.com/showthread.php?t=172691 }
But he was originally posting because he only got 3" of drop to begin with...
If you have a loaded CC/QC with rambox etc ,
you will get "more drop per coil" ...
Old 04-24-2014, 04:46 PM
Hornet is right:
my comment quoted above is misleading and should've clarified that was for a progressive coil as installed in the *rear* of our rams..
for the much shorter, stiffer, non-progressive fronts I would start with cutting 1/4 coil if I was aiming for 1" drop,
but they *are* a b*tch to swap in & out too ..
Old 04-25-2014, 11:25 AM
Buellrider's Avatar
Trim Level: R/t
Color: Wht
Rep:145
Yeah it RCSB.... Thanx for the info guys!!
2012 R/T
