Old 03-10-2014, 10:24 PM
anchorclanker's Avatar
anchorclanker anchorclanker is offline
Vehicle: 95 Ram 1500
Trim Level: Laramie SLT
anchorclanker is on a distinguished road
Default Headlights go out!?
Wondering if anyone else has had this issue.
I was heading to work the other morning and suddenly the headlights went out. I switched to high beams but they went out when I let go of the lever. Then the lights came back on. Friday moring nothing happened but this morning it happened again. This time I just ppushed the switch in and back out and all was good again. I'm thinking headlight switch but I'd like to hear if anyone else has had this happen before I take the switch out for nothing.
Old 03-10-2014, 11:18 PM
colododge96 colododge96 is offline
Vehicle: 1996 Dodge Ram 2500
Color: White/Grey
colododge96 is on a distinguished road
Hi Anchorclanker,
Havent had this problem om my ram; however did on a ford pu I had and I also thought was switch when it actually waas a wire. I concur the headlight switch is a good starting point or maybe the connection also.
Hope this helps
Andy
Old 03-12-2014, 11:17 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Had you been driving for a while? I live in the country. I had a 95 Ram. I would drive home with the hi-beams on. After 5 miles, they would cut-out. Sometimes could get the lows to work. MY problem was the main-feed of power into the headlight switch was melting at the connector. The terminal at the harness that fed the headlights, at the headlight switch, was backed-out, and melted. My cure was a headlight relay kit. This eliminated the power for the headlights running through the switch, and used the switch only as a relay trigger. Result was no issues, and brighter lights. Hope this helps. Cost was about $30.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 03-13-2014, 09:05 PM
Thumbs up
Laz,
I had been driving for about 15-20 minutes so I'm not sure if that would be long enough. But, that's good info for me to look for when I pull the switch out. Brighter lights would be worth it to install a relay too.
Thanks for the tip.
Dave
