Old 03-25-2014, 10:53 PM
TriSum's Avatar
TriSum TriSum is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:47
TriSum is on a distinguished road
Very anxious to see if this works. Thanks for being the guinea pig.....
David
2012 R/T
ARH Longtubes, Diablo Trinity, Flowmaster, Belltech 2"/4" Lowering Kit, Spohn Track Bar, Bak Flip "VP" Tonneau Cover, Oil Catch Can
Old 03-28-2014, 06:17 PM
SRT2RT SRT2RT is offline
Trim Level: R/T
SRT2RT is on a distinguished road
ok not to discourage anyone it does not work that said i am working on a way to make it work and it looks promising but will involve more parts getting ordered still will keep people well under what a big brake kit will normally cost
i will keep everyone updated on what i find
trying to get this under 1300 bucks and if it works that will be a steal
Old 03-30-2014, 12:41 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
subscribed!!!!!!!!!!!!!!
Old 03-30-2014, 07:50 PM
Trim Level: R/T
basically the factory spindle cannot be modified for obvious reasons its aluminum and just wouldnt be safe to modify. i am thinking the drop spindles from mcgaughys have a flat surface running in to the hub so with proper machine work the holes for factory hubs will be filled and new holes drilled . I know that mod wont be for some people but i am very optimistic also i have access to a good machine shop so everything will be done correctly.
Old 03-31-2014, 01:23 AM
TriSum's Avatar
Trim Level: R/T
Rep:47
Most aftermarket kits just provide a mounting bracket for the new caliper. I don't see why you would need to modify the spindle. The bracket will have enough room for two sets of mounting holes since you are usually mounting a larger rotor so the holes are far enough apart. The thickness of the spacer is what give you your caliper mounting location left to right and lines the caliper up on the rotor.
I hope that makes sense.
The issue is not really getting it to fit on the spindle, it is wheel clearance and the actual function of the caliper, (how piston size and pressure affect actual braking performance) on the vehicle.
David
2012 R/T
Old 04-01-2014, 09:47 AM
Trim Level: R/T
the caliper mount in the location of factory caliper mounts put 2-3inches away from the rotor so the mounting holes need to be moved inbound closer to the hub given the shape of the factory spindle and its aluminum construction i do not trust it to drill out nor would that even be possible with how it is shaped the drop spindles have a flatter surface and are a stronger material so i wouldnt be worried about planing it and drilling new holes.
stay tuned
Old 04-01-2014, 09:53 PM
I push the skinny pedal
Rep:3277
Ok, I know this is a shameless sales plug, but I am selling my slightly used (5000 miles) SSBC tri-power kit, matching rotors, and powdercoated oem rear calipers for $1000. I know it might be too late, but it's there if you get fed up with modding the modded modifications to make things fit.
Kurtis
Old 04-01-2014, 10:00 PM
Trim Level: R/T
Too small the srt8 brembos are monsters and only cost 250 each.
this is going to work and it might not be for everyone but ill be one of the few ram r/t with big brake kit
Old 04-20-2014, 03:16 PM
BlownGP's Avatar
BlownGP BlownGP is offline
Vehicle: 2009 RAM CC Sport
Color: Sunburst Orange Pearl
Rep:15
BlownGP is on a distinguished road
I would have never guess the GCSRT8 had 15" brake rotors. They look so small in pics..
Here's a good pic and info about the GCSRT8 Suspension/Brakes
http://www.edmunds.com/car-reviews/t...alkaround.html
Any updates on this by the way? Now with my 22s the truck stops fine but brakes look so tiny? I was about to paint them but if this upgrade is possible, might go that route.
98 GTP-Mods? Yeah, lots of them
2009 Ram CC Sport- Mods very SOON!!!
Old 04-21-2014, 01:05 AM
TriSum's Avatar
Trim Level: R/T
Rep:47
Can you get some pictures? Which direction is the 2-3" ? I haven't looked at the stock brakes to see how they are mounted, but 2 piece rotors are easy to source and can bring the caliper in or out to line up closer to the factory mounting location.
David
stay tuned
2012 R/T
