Old 03-12-2014, 09:21 AM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:39
BlackBullet is on a distinguished road
Default bad key fob?
truck wont start and is not showing any trouble codes. any chance a bad key fob is the cause? anyone have similar circumstances? on my way to the shop with my spare fob so time will tell, but, anyone?
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 03-12-2014, 05:02 PM
brucebigham brucebigham is offline
Vehicle: 2014 Dodge Ram
brucebigham is on a distinguished road
Very likely a bad FOB is the other FOB works fine.
HAVE YOU BEEN RAM'D LATELY?
Old 03-12-2014, 06:07 PM
Rep:2620
All 3 of my FOBs work, yes i bought more then i need, i had misplaced one of them for a couple months
I have found that any FOB can malfunction
sometimes the dealer has to do a re flash
sometimes the FOBs battery can have a bad contact
other times, like if you park directly in front of some stores, like the 7/11 & certain truck stops, all of the fluorescent lights, automatic doors, & cameras can cause a temporary malfunction. I now try to park further away from the windows & front door of the places that i know that i have had this happen to me in the past.
Other FOB information
Your Ram FOBs can have either Dodge or Ram printed on the outer case, the blank chip & battery are identical in both, mine has the Panic, Unlock, Lock, & Start buttons
The case marked Dodge is cheaper then the case marked Ram, if bought at the dealership
a Starscan tool is needed to program the blank chip to work with your vehicle, IF you have 2 working FOBs, you can program a 3rd FOB yourself
You can save money by buying a NEW blank FOB or a Transponder key online through IKEYLESS, the blank door & tailgate Valet Key that fits into the FOB costs extra
I didn't see a 4 button FOB on that website, so call them & ask about it
i can't confirm the part about ACE hardware in this film
Good Luck
Old 03-12-2014, 08:40 PM
CDNtbone303's Avatar
CDNtbone303 CDNtbone303 is offline
Trim Level: Bighorn
Color: Bright Metallic Silver
CDNtbone303 is on a distinguished road
I agree FOB might need a flash or bad FOB
Old 03-12-2014, 08:54 PM
mjsweeney205 mjsweeney205 is offline
Vehicle: 2007 ram 1500
Trim Level: tow package
Color: silver
mjsweeney205 is on a distinguished road
Having issues with my key fob. The doors would not open remotely but truck would start.
Replaced battery. now doors open remotely but truck will not start.
Is there a time limit on replacing battery. Hate to go to dealer. The spare was lost a long time ago.
Any suggestions?
Old 03-13-2014, 12:18 PM
Trim Level: TRX4
Rep:39
my spare fob did not work, back to the drawing board...
Old 03-19-2014, 07:53 PM
Trim Level: TRX4
Rep:39
bad fuel pump. only 26k on the clock, little disappointing. I bought an extended warranty when I bought the truck, so at least that worked out, I guess.
