Best Oil, Tranny Fluid and Rearend Oil - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 03-13-2014, 02:48 PM
Kruilty's Avatar
Kruilty Kruilty is offline
Vehicle: 1998 Dodge 2500 Ram
Trim Level: Laramie SLT
Color: Green ( Teal )
Kruilty is on a distinguished road
Arrow Best Oil, Tranny Fluid and Rearend Oil
So, by end of May, I'm going to be doing the pre-roadtrip thing. Making sure everything is good mechanically. Haven't had any problems yet with truck since buying back in November of last year. Now only has 94k miles on it. I'm looking to get some advice on best oils to use in this engine, tranny and rear end. Truck is completely stock except air bags on rear end. Or should I just use what's recommended? Or go to synthetics? Since buying the truck and using it daily, it hasn't used any oil. Although I only drive it about 12-20 miles a day. But it'll be time for a change just before the road trip. Bought the truck with 92k miles on it. So, in 4 months ive added 2k more. But now this road trip will add lil more than 7k in a weeks time. Will also be towing a uhaul trailer loaded (6x12 Im hoping), from Tn to Fl, then over to La to be dropped off. Any ideas for oils would be helpful. Truck is '98 2500 V10.
Old 03-14-2014, 03:33 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
I'd use the Mopar fluids. I know the differential lubes are synthetic, think the ATF+4 Mopar is also at least part synthetic. As far as engine oil, I'm a synthetic guy, I use Penzoil Platinum and change every 15,000 miles. I send a sample to Blackstone Labs. I'm sure any premium mineral oil will be fine with reasonable changes, though. I know some guys switch from 75/140 to 75/90 dif lube and claim better economy.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 03-17-2014, 10:34 PM
Cheatham Cheatham is offline
Vehicle: 2012
Color: Grey
Rep:17
Cheatham is on a distinguished road
i like royal purple oil and stick with atf 4 dont forget your wheel bearings too re pack them
oil, road trip, synthetic
