Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > MOPAR NATION - Dodge Ram Club Regional Chapters! > North West
North West AK, ID, MT, OR, WA, WY
Old 03-13-2014, 07:08 PM
bolo1g2 bolo1g2 is offline
Trim Level: Crew Cab Big Horn
Rep:19
bolo1g2 is on a distinguished road
Default Lift installation in Western Washington?
Hey all. Getting ready to pull the trigger on a lift, wheels and tires. I won't be able to DIY this one, so I'm wondering if any of you all are in Western Washington and can recommend a shop for install. I've called around every where from Les Schwab to the mom and pop mechanic and am getting quotes from $850 to $1200 for install. I feel like that's high, but maybe I'm high? Any tips or recommendations are appreciated.
Old 03-19-2014, 12:44 AM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
Where in Western Washington are you?
Old 03-19-2014, 02:05 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
thats accurate for a 6" lift with adjustable struts, extra rear coil spacer around here, there are a few shop that'll do it for $600, you figure most shops charge between $60-$120 per hours, and most lifts take between 8-12 hours (book time) to install, shops that do lifts all the time will do it in 6, the shop I go to doesn't even use a lift to install lifts they use jack stands and floor jacks and takes 1 guy about 6 hours for most lifts, if there is two of them working on it they generally do it in 4.
Old 03-23-2014, 08:57 PM
Rep:19
I'm in the South sound, Lacey/Olympia/Tumwater area. Where are you boosted?
Old 03-23-2014, 11:13 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:94
Hey bud...these guys are Tacoma...
http://www.4wheelparts.com/stores/StoreLocator.aspx
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter, SuperChips Flashpaq 3482
