Complete Brake Replacement - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Dodge Ram Aftermarket Brakes
Dodge Ram Aftermarket Brakes Aftermarket Big Brake Kits. Not for discussion of General Brake Maintenance.
View Poll Results: Who sells the highest quality brake parts?
AutoZone 2 22.22%
O'Reilly's 1 11.11%
Advanced Auto Parts 1 11.11%
Napa 5 55.56%
Voters: 9. You may not vote on this poll
Old 03-16-2014, 10:07 AM
cmm47172's Avatar
cmm47172 cmm47172 is offline
Vehicle: 2008 Dodge Ram ST
cmm47172 is on a distinguished road
Question Complete Brake Replacement
Iíve decided to replace my brakes i.e. pads, rotors, drums and shoes.
I have a 2008 RAM 1500 ST Regular Cab with 90,000 miles.
The rotors seem to be getting warped as I feel a shake in the front end whenever I break heavy.
I never haul anything really heavy or pull a trailer.
I use my truck to go back and forth to work, thatís about it.
Iím looking for the best brake products available.
Iíll probably go with ceramic pads to cut down on dust and noise.
Ultimately, I want a quality product over price.
Itís been awhile since Iíve done a break job so Iím looking to see if anything new exists on the market that I should consider.
From what Iíve read, most everything comes from China/Asia these days so it really doesnít matter where you buy as the product is likely to be as good from one store to the other.
Is this true?
Does anyone have an opinion on this?
Should go to Autozone, OíReillyís, Pep Boys, NAPA or somewhere else?
Where do the OEM brakes come from?
Would OEM be any better than anything else?
Aside from using ceramic brakes and lubricants, what is the best way to reduce brake squeaks?
Old 03-16-2014, 10:20 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Here's a trick that you can do to fix your rotors: Find a road with no traffic, drive at 60 mph, apply the brakes firmly without having ABS cut in, slow down to 5-10 mph, speed up to 60 and repeat as many times until brakes start to fade=5 times maybe as many as 10. Once they fade, speed up and drive as fast as you can legally, faster the better for a few minutes. This will straighten the rotors and impress a layer of pad material onto the surface of the rotors and create better friction. When you buy pads, Mopar Premium pads are about as good as they get, check for warrantee. I believe they have a lifetime warrantee. Don't buy crappy Chinese aftermarket rotors. I did not vote, the best are Mopar.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 03-16-2014, 10:26 AM
cmm47172's Avatar
As soon as I posted this I realized that I have rotors on the back, not drums.
Are the rotors on the back bigger than the front?
Old 03-18-2014, 04:34 PM
cmm47172's Avatar
I just noticed the post from Hydrex. I may get booted from this forum after I make my comment. So what he is saying is to heat the brakes to a point to where they start to fail and then drive as fast as you can to work out the warp and or fuse pad material to the rotor. That has to be the most stupid FU%$ing thing I have ever heard, not to mention very dangerous. Anyone reading his post should not follow his moronic advice.
Sir, you are complete idiot.
Old 04-08-2014, 10:44 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:801
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
he did say find a road without traffic.
Old 05-23-2014, 03:45 PM
Livewire1968 Livewire1968 is offline
Vehicle: 2010 dodge ram 1500 sport
Livewire1968 is on a distinguished road
I am changing mine this weekend also, warp issue. I upgrading to EBC slotted dimpled with 7000 series in the front green and 6000 series green in the back.
Old 05-26-2014, 01:38 PM
Rep:801
are the slotted rotors worth the extra money?
brakes, pads, rotors, shoes, squeak
