Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > VARARAM - Dodge Ram Performance!
VARARAM - Dodge Ram Performance! Vararam Industries was created to bring true racing technology to the street, the most efficient air induction systems on earth. Our air induction systems produce more Power and Torque, offering you more real world performance than any of the other intake system out there, We've been tested to be the best, compared to the rest and each time VR comes out on top. - Dodge Ram Performance!
Old 03-16-2014, 07:42 PM
bluedieselram's Avatar
bluedieselram bluedieselram is offline
Vehicle: 04 RAM 1500
Color: gold
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
bluedieselram is on a distinguished road
Default benefits for an 04
what kinda power & mpg gains would my 04 ram with a 3.7 get & about how much for the cai?
04 ram 1500 3.7 stock for now
99 ram 2500 5.9 k&n intake with stacks waiting be put on
Old 03-17-2014, 02:37 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Unless the throttle body is in the same place as the hemi , it probably won't fit. You might want to get out your tape measure and find a buddy with a hemi to compare. Also, 2 different systems, 1 for the hemis up thru 2008(Hemi under Glass) then the one for 09 up. 1 or the other might be able to work, or not. 1 caveat, if you get it to work , the extra air could cause a lean condition, at the least you might need to run 1 grade better gas.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
