Old 03-17-2014, 07:14 PM
Black Diamond 357's Avatar
Black Diamond 357 Black Diamond 357 is offline
Vehicle: 2012 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Black Diamond
Rep:25
Black Diamond 357 is on a distinguished road
Default Lights flickering
Ok, here is my situation! I have 2 tens,1500 watt amp,2 farad cap,4 gauge wiring. So when my truck hit hard bass lines I noticed my lights are flickering something awfully bad! So do I need to get a extra battery or upgrade to high output alternator?
Old 03-18-2014, 12:14 AM
bolo1g2 bolo1g2 is offline
Trim Level: Crew Cab Big Horn
Rep:19
bolo1g2 is on a distinguished road
Alternator can't handle the wattage. Caps are useless. Get a bigger alternator.
Old 03-18-2014, 01:46 AM
Rep:25
That's what I was thinking I need
Old 03-18-2014, 07:31 AM
huff73541 huff73541 is offline
Vehicle: 2007 Ram 1500 Big Horn
huff73541 is on a distinguished road
i would try to upgrade you power wire from alt. to batt. and your ground wires..this mod is known as the "Big 3 Upgrade"
This upgrade will only help you...you may need a bigger alt. or second battery but I would upgrade the wires first...
This is just one example I found but there are several on this forum and others...
http://www.stevemeadedesigns.com/boa...big-3-upgrade/
Old 03-18-2014, 03:51 PM
Rep:19
Big 3 could make it worse since the power consumption would be more efficient. If the wattage is too great on the overall electrical system, the big 3 would just make the flow better. I agree the big 3 is a great upgrade but doesn't treat the actual issue. Voltage x the Amperage draw x amps efficiency = Watts.
Old 03-20-2014, 01:45 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:83
Bushmaster will become famous soon enough
I would add both. On my previous vehicle I upgraded the alternator and put a gel cell battery in it(stereo only) and never had a problem.
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 03-22-2014, 11:55 PM
Superduper Superduper is offline
Vehicle: 2013 Crew Cab
Superduper is on a distinguished road
My headlights dim if I hold the windows up button haha. Dodge has pretty bad electrical.
Old 03-23-2014, 10:05 AM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
That's a pretty broad statement that I will have to disagree with...
if your windows are dimming your lights, YOUR electrical system has some issues.
With that being said...OP, your amp(s) may be the culprit too, and the cap is doing nothing for you but that's another story.
Iam currently running well over 2000 watts from four class D amps in my truck and my lights do not dim at all. Iam registering atleast 14.5 volts at all times (including during big bass hits)
I have the factory battery and have done zero electrical mods to the truck.
Different class amps draw more or less power from your electrical system.
Your alternator may not be keeping up with the voltage needs (you can get that checked for free)
Old 03-23-2014, 10:43 AM
Rep:25
Update..... Now my dang amp is going into protect mode. I touched it yesterday and it was warm.
Old 03-23-2014, 11:43 AM
Rep:19
Sounds like you got issues. Get some pics of your set up. Your gains could be up too high.
