Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 03-19-2014, 06:45 PM
Lincoln5.7's Avatar
Lincoln5.7 Lincoln5.7 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT Big Horn
Rep:26
Lincoln5.7 is on a distinguished road
Default New to NOS need help?
Hi, ive read almost every thread I can on here and a couple other forums and while ive learned a lot I still have some questions.
the things ive learned are...wet system is safer than dry, nitrous express is a pretty good brand to go with, and I should be able to safely run a 75 shot of N2O on practically stock engine and a completely stock tranny.
I wouldn't want to pay anyone to install and would like to do it myself (yes I know theres still a lot to learn before doing this) but there are a couple questions I have.
heres the link to the kit I was thinking about getting: http://www.nitrousexpress.com/70569/...lb-bottle.html
I know id have to get a bottle heater and all that jazz, my question is I know everybody likes the throttle plate, but if im running only a 50 to 75 shot is it worth it to pay the extra for the plate? also where do you tap into the fuel that goes into the solenoid mixed with nos? and where does the actual spray nozzle mount to get the mixture into the intake?
the videos at the bottom say that it comes with the switch that only allows nos to be sprayed between certain rpm ranges...so would I need the window switch aswell or is that what that is?
sorry for the newbie questions I just want to do it right if I put the money and time into doing it. thanks for anyone who can help me out
Bullydog GT Programmer Tuner, Flowmaster 40 series, 2 Polk MM1040's, 85mm Throttle body, Volant Powercore CAI, McGaughy 2in drop shackles, 22x10 srt10 rims, CCFL Halos, Belltech Street Performance Shocks.
Soon to come: 4.56's and Pacesetter LT with Y-pipe, Cat delete.
Old 03-19-2014, 08:51 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I like to have the button to spray mounted handy to my right thumb. If I'm having traction problems, I can blip it until it hooks up. A 10 lb bottle fits nicely under rear seat. Use a heater with auto shut off pressure switch. For a 100 shot, run 1 range colder plug, gapped .35. Run 1 grade higher gas if you can or 1 bottle NOS brand octane booster to half a tank or less gas. Pick up the gas from a Schrader valve in a fuel rail. Just spray a 100 shot at 2800-3000 rpms and wot. Let off the nitrous button as soon as you go thru the traps, but never let off the gas until you let off the nitrous button. If you go the "hot button" route you have instant ability to let off the juice, but you have to treat that button almost like a loaded gun! If you hit the nitrous at anything but wot and over 2800 rpms, you will break your motor. Make sure you have a blow down tube that goes thru the floor, should the system overpressure. Get a Sonnax line pressure booster for your transmission. Spray only at the track, it's illegal to spray on the street!
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 03-19-2014, 10:21 PM
Lincoln5.7's Avatar
Rep:26
thank you for your reply. instead of running a "hot button" a lot of people use a switch that mounts and only allowes the nos to be sprayed at those certain rpms you set it for once you flip the switch and "arm" the nos system. do you think that's a safer route for me since im new to it and if I accidentally hit the button at the wrong time?
also I was reading about the colder plugs you were talking about. how much do those run price wise? thanks for your help I appreciate it.
Old 03-20-2014, 10:50 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
he nailed it pretty much on the head
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 04-18-2014, 10:27 AM
rjs1210 rjs1210 is offline
Vehicle: 2012 Dodge Ram
rjs1210 is on a distinguished road
I personally ran a wide open throttle switch and a window switch on one of my GM's. I was running a manual trans at the time and that allowed me to focus on shifting rather than letting on and off a button. I programmed the window switch to shut off 200 below my shift point in addition to the wide open throttle switch that would disengage when i lifted, probably overdone but never worried about anything while running it.
Old 04-21-2014, 01:09 AM
Lincoln5.7's Avatar
Rep:26
thanks for the input. but does that do anything to help with spinning tires. I feel like if I did that I would spin like crazy. did you set up a purge kit? and did you spray through all your gears?
Old 04-21-2014, 10:34 AM
when at the strip, with better tires and a better prepped surface i would not spin very much at all and yes i went through all gears. On the street since I wouldn't be able to go full throttle right off the line it was manageable since i was at a higher MPH when i was finally able to put it all the way to the floor and activate the wide open throttle switch.
Old 04-21-2014, 08:11 PM
Lincoln5.7's Avatar
Rep:26
ive been back and forth about either going with the window switch or the hot button and I plan to do the install here in about 6 weeks. I just don't know how hard it is to hook up the tps sensor and window switch to the system. did you put all your in by yourself?
Old 04-22-2014, 08:41 AM
Trim Level: st
Color: silver
Rep:68
Get a nitrous outlet plate it so much nicer trust me go get one from ls1tech or any form used i got mine for 100 bucks not bad at all.
Old 04-22-2014, 12:38 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
although I use nitrous pretty frequently at the track, I do consider myself still an amateur in regards to nitrous so I pretty much keep it as a safe setup. Altho I am running a plate, I use to run a nozzle tapped into a tb spacer which worked just as good. I run a step colder plug (NGK 4306) which I run all the time. I do make it a habit to change my plugs frequently (every other time I go to track) just for insurance sake. I run the Zex nitrous wet system which has the solenoids in a little black box which makes it simple for me to setup. I do run a wot pedal switch which sprays at a higher rpm (not sure what it is) and will stop when below that rpm or when I'm off the pedal... I use to have the problem of spinning off the line spraying and what I did initially was feather off the line before nailing it but then I lost potential e.t.'s because of the slow start. To offset that I got a cig lighter power switch to run my nitrous off of. What this did was make my setup 'portable' which I could hide the power when not in use, but more importantly, it gave me a switch I could flip once I leave the line on wot na for 60 ft or so and then flippin the switch which is like pushing the button...and for safety sake, it allows me to turn off the system after I pass the traps so I don't inadvertently light up if I blip the throttle afterwards.
