Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 04-22-2014, 12:47 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
here is a run where you can tell I didn't hit it til like 30 ft out..
-fast freddie- one quick 05 hemi qc...with over 275k miles on odo... on the 5.7, stoker 6.4 now...Inertia Motorsports 392 stroker
Old 04-22-2014, 04:08 PM
Lincoln5.7's Avatar
Lincoln5.7 Lincoln5.7 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT Big Horn
Rep:26
Lincoln5.7 is on a distinguished road
man that looks sweet. I was thinking of doing the tb spacer with the tapped nozzle aswell. I was looking at the hemi truck kit from zex, it has a purple NMU (nitrous management unit) which im sure is the same thing as your black box. do these kits come with the WOT sensor in them or would I have to get that separate? and if you hook up an arming switch and a TPS WOT sensor does that allow it to cut of the NOS at your shift points and when your under 3000 rpms off the line?
only reason I ask is because from what ive read you don't want to spray through the shift or while your under like 2800 or so. To do that wouldn't you need the Window switch to set at different RPMs?
Or could you do what Hydrex said and get a hot button and when you get above 3000 rpms pressit then right before like 5300 let of it and repeat that going through all the gears?
Thanks for all yalls help on this. theres a lot more that what I thought after I started doing the research.
Bullydog GT Programmer Tuner, Flowmaster 40 series, 2 Polk MM1040's, 85mm Throttle body, Volant Powercore CAI, McGaughy 2in drop shackles, 22x10 srt10 rims, CCFL Halos, Belltech Street Performance Shocks.
Soon to come: 4.56's and Pacesetter LT with Y-pipe, Cat delete.
Old 09-16-2014, 05:55 PM
HammerHead's Avatar
HammerHead HammerHead is offline
USMC 0313
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
HammerHead is on a distinguished road
^^^ that's awesome
Geared-Tuned-Shift Kit 14.0@96
Proud member of the 4 second club...
Old 09-19-2014, 01:08 PM
chefred112's Avatar
Rep:656
Yup...mine was purple..I painted it black to be inconspicuous , the nmu has everything, you just tap the tps wire onto the pedal sensor (seems to be the 2nd wiring) and that will take care of when the nitrous lights up. I just took this pic for Mike for reference:
Old 09-19-2014, 01:11 PM
chefred112's Avatar
Rep:656
also, for power wiring, i hooked it up to a cig lighter acc switch so that I can tell it when to hit...at the track if I hit it from the gitgo I'll spin so i keep my thumb on this switch til about 60ft out and then turn it on to light it up...
Old 09-20-2014, 06:52 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
You obviously spray through your shifts. I've never heard its bad to spray under 2800, only thing is that the engine isn't flowing as much air but I doubt it would puddle nitrous in the intake.
I am going to wire mine to an on/off switch but mount the switch in the dash, and use a WOT tps voltage switch. I think the Zex is one of the better kits so that is what I'm going to go with although I might buy a hemi throttle plate from Nitrous Express and use that instead of the nozzle that the zex kit uses. If it spins too much then I will install a window switch and set it from 3000-6000 RPM so that when I'm on the line it will roll a bit before the nitrous comes on at 3k.
Fred's powering on his system once he's past the 60 foot so that's sort of like a window switch but more so like a delay box. Say you know your truck 60 ft's at 2.1 seconds consistently so you set a delay box up for a 2.5 sec delay at WOT. It won't engage til your 2.5 seconds out which puts you past the 60 ft mark.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 09-23-2014, 12:41 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Going to set up up and test this week if i can ever get time to look at the truck.
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
