Old 03-23-2014, 01:01 AM
Hemitron Hemitron is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Hemitron is on a distinguished road
Default Minor HI beam HID problem
Before I go out and buy a new bigger and better battery I wanna know some opinions first.
When driving down the road at night with my 8000k "Beamers" Hi-Beam HIDs that I purchased and got installed by Custom Truck Parts (CTP) here in Grande Prairie, AB sometimes they like to shut off and immediately turn back on! There is a relay harness installed aswell. I've noticed this only happens from certain triggers like: using power windows, my aftermarket sub (Alpine Type-R Flatty) hitting very low notes at high volumes, and possibly my traction control kicking in (I think just discovered this one). There may be other triggers, some I possibly forget or some I haven't found yet. I need some opinions... Do you think it's my battery? Alternator? Maybe something else? Has anyone had this problem?
Hope we can figure this out! :P
Thanks alot
Old 03-23-2014, 01:04 AM
2nd problem...
Don't mean to double post, but also before I had my Beamer fogs in as well, I had a cheap no name eBay brand HIDs that causes my tire pressure sensor to go off every time they would go on or off. The issue is still there with my Beamer fogs.
Old 03-24-2014, 08:32 PM
No one has any feedback? :s
Old 03-25-2014, 05:16 AM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Trim Level: Longhorn
Color: Western brown
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
If your altanator is having issues you should see a warning on your cluster. You could measure the voltage across the battery while the engine was ideling with a voltmeter, voltage should be greater than 14 volts if the battery is charged.
Since HIDs pull about have the current of halogens, a bigger battery is not going to fix your problem unless you have a bad battery to start with, since you can repetitively start your engine, your battery is good.
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 03-25-2014, 06:48 PM
Hmmmm, I'm sure the volts would be right, but I could check. This is a real odd problem lol
Old 03-25-2014, 07:33 PM
Guls Guls is offline
Vehicle: 2014 Dodge Ram Bighorn
Trim Level: Bighorn
Rep:14
Guls is on a distinguished road
Hemitron, in my experience I have tried all different brand HIDs on new Chrysler vehicles and it has not worked. I think there is an issue with Canbus.
Old 03-26-2014, 12:40 AM
BC18471's Avatar
BC18471 BC18471 is offline
Vehicle: 2011 Dodge Ram
Color: Gray
Rep:31
BC18471 is on a distinguished road
I would guess you didn't get a very good kit so when you draw that extra power from the relay/capacitor, you may not be getting enough power. Like the previous poster said, the canbus systems are a PITA and very finicky.
Custom Katzkin leather, Magnaflow 14" with Y, Mopar CAI, Moroso Catch Can, 180* t-stat, Switchback Front turn signals, All LED lighting, Kenwood DNX6180, Cabin air filter, Smoked Tails and 3rd, Audiovox backup camera
Old 03-26-2014, 05:11 AM
Rep:470
Not really, if just have to understand how bulb-out detection works and what the power to the headlamps looks like. I have a picture of the power feed in my gallery and have written how they work in other threads.
Please quite calling it a can-bus system, it isn't and I have no idea why it is called that. CAN-bus is a controller network communication systems that exchanges messages made up of signals used in vehicles.
Old 03-26-2014, 03:42 PM
BC18471's Avatar
Color: Gray
Rep:31
Our trucks have a canbus system which require a special relay harness. Since you were not aware of this, you may not have the correct harness which could be causing your problems.
Do a search for canbus in the lighting section and you will see that our trucks in fact have a canbus system which our headlights are a part of.
Old 03-27-2014, 04:47 AM
Rep:470
What is a CANbus system with respect to our headlights?
