Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 6.4 HEMI V8
Custom Dodge Ram Performance Mods - Engine - 6.4 HEMI V8 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 6.4-liter HEMI® V8 engine - 410 horsepower, 429 lb-ft of torque.
Old 03-23-2014, 10:07 AM
Austin325 Austin325 is offline
Vehicle: 2014 ram 2500
Trim Level: St
Austin325 is on a distinguished road
Default Cold air intake for 2014 2500 6.4l?
Does anyone know of a company that makes any cold air intakes for the 6.4l, so far I can't find anything for this truck yet.
Old 03-23-2014, 11:09 AM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
I would contact S&B and see if their newer #75-5066 kit will fit. I've got one for my 5.7 2500. Not sure how different they are under the hood.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 03-24-2014, 08:03 AM
Trim Level: St
Cool thanks for the info.
Old 03-24-2014, 08:23 PM
kozzy kozzy is offline
Vehicle: 2015 Ram 2500 Big Horn
Color: Deep Cherry Red
kozzy is on a distinguished road
Austin, I would save your money, I put one on my CTD I had, and my MPG actually went down. I tried both an enclosed box, and the open type. it sounded nice, but that was about it. I ended up returning it, did TONS of research , there was actually a good site that had a ton of info, but I cant remember it, anyways, after all my digging I came up with a few conclusions.
The new air intake systems for these newer engines are exactly what they need, and performance is negligible at best with an aftermarket. Turned out the best thing to do was to just replace the stock air filter with a high flow dry air filter (not oiled , like K and N) so I did that....I noticed a 1-2 MPG gain and it did beefin up the sound a bit. it was made by AFE...I will be doing the same thing to my 6.4 HEMI as soon as they have a filter to fit it. Just my 2 cents
Old 03-25-2014, 08:41 AM
Trim Level: St
Great info , I do love how the intake makes the truck sounds I was just hoping to gain a little bit more torque and hrsp. I'll look for a dry filter though do you remember if they sell them at the local parts shops ( oreilly, advance, napa) or is it something I need to order online.
Old 03-25-2014, 09:33 AM
Olli Olli is offline
Vehicle: 2014 2500
Trim Level: CCSB 4x4 Laramie
Color: Max Steel
Olli is on a distinguished road
The 5.7 and the 6.4 apparently share the same filter element. I have not verified this though. You can. Call your dealer's parts dept. and have them compare the part numbers. If it checks out that the 5.7 and 6.4 use the same air filter, do a look up with AEM for their "Dry Flow.
Or use this link...
http://www.aemintakes.com/search/pro...?prod=28-20247
Olli
Old 03-25-2014, 01:58 PM
google AFE Advance Flow Engineering. I like their dry filter, and they are pretty good. I believe XDP sells them, although I am not sure of any local store that does. I would stay away from the oiled filters though.
Old 06-07-2014, 02:52 AM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
Any updates on filter replacement?
Old 06-07-2014, 01:24 PM
I haven't looked in awhile. Ill probably check today now that it is fresh in my mind again.
Old 06-13-2014, 11:23 AM
HorseMan's Avatar
Rep:139
I know the K&N filter 33-2247 will fit the 6.4, but has anyone checked for updates in a while? Anyone using the K&N or another filter on the 6.4? Any mileage improvements?
