Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 03-23-2014, 09:15 PM
SouthernDawg SouthernDawg is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: Basic
SouthernDawg is on a distinguished road
Default 1997 Dodge Ram cooling problem
Have a problem with my dodge ram cooling. The temp gauge reads normal. There is no leakage from water pump or noise. The top hose will get hot and the bottom hose will stay cold. Thermostat replaced about 1 yr ago. So thinking a bad radiator? Bad water pump or should I go ahead and replace the thermostat and start there. Thanks for the help.
Old 03-24-2014, 01:57 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I think you pretty much answered your own question. But, as a second opinion, if your top hose (in) is hot and your bottom hose (out) is cold, then you're not getting any flow through your radiator.
