HID kit questions... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 03-27-2014, 06:33 PM
ramhemi57's Avatar
ramhemi57 ramhemi57 is offline
ramhemi57 is on a distinguished road
Default HID kit questions...
going to be installing an HID kit for my 05 hemi... I have the hi beam kit not bixenon so its a low beam xenon and hi beam halogen. im afraid that this kit might blow a "fuse" which will take out the FCM (front control module) because that's the only "fuse" for the headlights is that module. im just afraid that something will get corroded or short out and will take it out at the FCM not a fuse because there is no fuse... is this something to worry about?
Old 03-27-2014, 07:18 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I don't think it would. I've been running HID's on my low beams for going on a year now with nary an issue. Have them on my fogs as well. Both are working trouble free.
Old 03-27-2014, 07:29 PM
ramhemi57's Avatar
hmm okay... I also have HID fogs and never had an issue. but those have a fuse, the headlights don't. so im a little hesitant and don't want something to short out and take the module out because there's no fuse for the headlights.
Old 03-27-2014, 07:39 PM
Rep:2968
I bought Spyder head lights with separate hi and low beams. Low beams are HID, hi beams are not.
Old 03-27-2014, 07:50 PM
easy e's Avatar
easy e easy e is offline
Vehicle: 2007
Rep:21
easy e is on a distinguished road
For any HID on high or low beam should have relays and 50w 6 ohm resistors (it's not expensive). The hi and low beams are definitely canbus, but fogs are not for 3rd gen.
If you don't add these your lights may flicker, but more importantly you run the risk that the HID will damage your electrical system over time since it was designed for canbus. On initial bulb warmup, the HID causes a electrical current spike that over time can damage your electrical system as it wears down contact points. Once the HID warms up it draws less current then the canbus.
Fogs shouldn't be an issue for 3rd gen since they are not canbus.
2007 Hemi SLT 4x4 Quad Cab
260k miles and counting...
Old 03-27-2014, 08:09 PM
ramhemi57's Avatar
I appreciate that information a lot... could you explain real quick what I need to do and how to hook that up? so I buy 2 relay kits or 1? each HID bulb and ballast is wired to each side... not wired together so do I need 2 relay kits or just 1? and same with resistors...
Old 03-27-2014, 10:39 PM
Rep:2968
Here are the light's I bought.
And here are the canbus/anti flicker adapters I bought. 2 relays came in 1 kit.
Old 03-29-2014, 03:21 PM
ramhemi57's Avatar
thank you... will that protect my Front Control Module? that computer Warning Canceller & Anti Flicker kit?
Old 03-29-2014, 08:37 PM
Rep:2968
I can't guarantee that, but it has protected mine.
Old 03-31-2014, 07:14 PM
ramhemi57's Avatar
okay... thanks! will that kit basically act like a fuse and blow before reaching the module? is that the point of it?
