Old 03-28-2014, 09:58 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
Default Alpine 8" to JL 8 "
Does anyone know or think if I switched out the Alpine 8 SUB under my seat with the JL audio 8 if there would be much of a difference or worth it ? would like to use same enclosure if possible. what about an amp ? THANK YOU
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter
Old 03-29-2014, 09:49 AM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
To accurately answer your question, we need to know what Alpine 8" subwoofer specifically, and what JL Audio 8" subwoofer specifically. Both manufacturers have a few different model of 8's.
AND, we need to know the type of subwoofer box ported or sealed, and internal box volume of subwoofer box.
And are you asking about an amp to run the subwoofer?
Old 03-29-2014, 10:17 AM
Black Diamond 357's Avatar
Black Diamond 357 Black Diamond 357 is offline
Vehicle: 2012 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Black Diamond
Rep:25
Black Diamond 357 is on a distinguished road
I believe if you use the same enclosure it will sound like straight crap! You can always make a fiberglass box that will sit low enough so you can use your fff. And use a shallow mount sub
Old 04-08-2014, 09:25 AM
scottishtornado scottishtornado is offline
Vehicle: 2012 ram laramie
Trim Level: leather
Color: silver
Rep:78
scottishtornado will become famous soon enough
I have a JL W3 shallow mount sub in a custom ported box and it sounds awesome. The choice of box is important, ported boxes are boomier where enclosed are punchier so it really depends on what music you play and what your looking for. The stock box will flex as its plastic and will not bring out the best performance of a new sub.
Old 04-08-2014, 09:32 AM
05cr125r's Avatar
Rep:116
thats what i was wondering, if i could use the same box or not. I do want the punch, so thanks for explaining that. Guess i need to get off my butt and look more into this. can you recommend a box ? JL makes one i want and that $650 for box and sub.........
