Old 03-29-2014, 05:35 PM
JEDS67 JEDS67 is offline
Vehicle: 2003 Dodge Ram 1500
Color: Almond Pearl
JEDS67 is on a distinguished road
Default DRL Location 2003 Ram 1500
Just looking for the location of the drl module on line myself but I can't seem to find it.I would like to change it as I am having problems with one day lamps not coming on and also the headlight occasionally on the same side.Some have said it is on the left fender and now the firewall.Any suggestions would be greatly appreciated and thank you for your time.Jeds67
Old 03-29-2014, 09:49 PM
RogerRamJet's Avatar
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2933
You don't have a DRL module, it's a setting in the Forward Control Module. Here's what the service manual says about it.
DAYTIME RUNNING LAMPS
Vehicles manufactured for sale in Canada illuminate the high beam filament of both headlamp bulbs at a reduced intensity when the engine is running and the exterior lamps are turned off. The FCM must be programmed with the appropriate country code for this feature to be enabled. Once enabled, anytime the FCM receives electronic messages over the PCI data bus from the PCM indicating the engine is running and from the EMIC indicating the status of the headlamp switch exterior lighting input is Off, the FCM provides a pulse width modulated voltage output to the proper headlamp bulb filaments through the right and left high beam output circuits to produce illumination at a reduced intensity.
NOTE: Before performing the following tests, determine whether the headlamp low and high beams operate.
If the headlamp low and high beams are also inoperative, diagnose and repair that problem before attempting
to repair the Daytime Running Lamps.
CONDITION
WILL NOT ILLUMINATE
POSSIBLE CAUSES
1. Incorrect FCM programming. 2. Faulty FCM inputs or outputs.
CORRECTION
1. Use a diagnostic scan tool to check and
program correct country code into FCM as
required.
2. Use a diagnostic scan tool to test the
FCM inputs or outputs. Refer to the
appropriate diagnostic information.
Old 03-30-2014, 08:18 AM
Color: Almond Pearl
I guess that is why I can't find it.Time to take it to a shop for a scanning tool.Thank you for your time.Jeds67
Old 08-08-2014, 06:11 PM
v1shusHEMI v1shusHEMI is offline
Vehicle: 2007 HEMI RAM
Color: GREY
v1shusHEMI is on a distinguished road
RogerRamJet
Does this mean its something as simple as changing the country code? I have a Canadian '07 Ram and would like to move the drl's to a different set of lights. Is it as simple as taking it to a dealership and having them change the country code to US or Mexico? If US models can be made Cdn to turn the drl's on can I do the reverse without any issues? I'd hate to fry the TIPM.
I have spoken with a dealer and they will do the change for me but are concerned that changing the code may create other problems?
Appreciate any suggestions or comments!
Old 08-09-2014, 01:51 AM
Rep:2933
Honestly Van, I don't know what, if any, problems changing country codes would create. If you're that concerned, I'm thinking you should probably not do it, then.
Old 08-10-2014, 10:32 PM
Color: GREY
Thanks for the reply.........
Personally I wasn't concerned but the dealership was.......... and because of his concerns I am now questioning it. I was hoping to find some one that has done it just to get a voice of experience. I think I'll go ahead and have them do it. Thanks again!
Old 08-11-2014, 01:17 AM
Rep:2933
Kewl. Keep us posted on the outcome.
Old 08-12-2014, 03:13 AM
Color: GREY
Wiil DO! Since I live in Vancouver Canada I have to make time to get down to Seattle..... hopefully in the next week or so! I'll update when done
Old 09-16-2014, 01:13 AM
Color: GREY
Okay, all done!
My truck is now a US citizen! Wish it was that easy for me, I'd move down in a flash lol.
So my country code is now US and the parameter to turn OFF drl's now shows up. We turned off the drl's and EVERYTHING else is functioning normal. It took about 15 minutes.
For anyone that wants to add aftermarket projector lights and swap to a 4 light system and is having issues with all four lights coming on, changing country code works!
I am now going to add a drl module and either add aftermarket lights or add a relay and run switched power to the fog/running lights and make those my drl's. Does any one know if its possible to do this, so the fogs come on when I turn key on AND still have functionality of turning the fogs on via the dash light switch? Or do I have to disconnect the fogs and only use them on the relay as drl's, will this trigger a fault code?
Color: GREY
Default US citizenship
Okay, all done!
