Installing a Dump Valve with the TLC - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 03-29-2014, 09:40 PM
BigDawg 2013 BigDawg 2013 is offline
Vehicle: 2013 Dodge Ram Quad Cab
Trim Level: Bighorn
BigDawg 2013 is on a distinguished road
Default Installing a Dump Valve with the TLC
Has anyone else installed a dump valve in the TLC system. I just bought the system and like the idea of able to adjust the air bags .
Old 03-30-2014, 10:51 AM
CopperheadSporty CopperheadSporty is offline
Vehicle: 2013 Ram 1500 Sport
Color: Copperhead
CopperheadSporty is on a distinguished road
I'm in the process of doing that. Purchased an ASCO solenoid valve model SC8238T402. It's 12v and normally closed. 40 bucks on eBay.
Going to wire it and the compressor to a momentary on-off-on switch in my cab.
