Old 03-30-2014, 02:20 PM
bdemutis bdemutis is offline
Vehicle: 1995 dodge ram 2500 5.9l 360ci
Color: blue
bdemutis is on a distinguished road
Default Front brakes grabbing when easing into stop
So when I'm driving and I ease my brakes into a stop and I start easing into them more to stop fully the front brake grab all of the sudden and lock up and I skid it happened a few times yesterday and it's been pouring I slid out into a intersection almost. I don't know whats wrong I did just recently put a emergency brake line tensioner on to fix my emergency brake line. The guy I bought the truck from put all new rotors on brakes ect. I did replace a blown brake line during the summer on my front right side that blew. I don't know what it could be I need help.
Old 03-30-2014, 02:36 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I would be checking for another blown brake line, with one blown he should have replaced them all IMHO. Grabbing as you have described is usually caused by contaminated brake pads. Could also be seized pins but if you recently had new pads and rotors installed he should have lubricated up all the slider pins.
Old 03-30-2014, 07:24 PM
Color: blue
Ok thanks I'll check my pads tomorrow after work. Also when my brake line blew we checked all the other ones and they were good only reason I knew it was blown was because the ABS light came on.
Old 04-01-2014, 10:48 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Could it be because your rear brakes are out of adjustment? And you are are only using the fronts to stop? Rears adjust from regular use of the parking brake (yeah, I know thats crazy), and firm stops in reverse.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 04-08-2014, 12:27 AM
Color: blue
Sorry I haven't posted but that was the problem I have been busy working but my rear brakes need to be adjusted that's funny because my emergency brake was broken the cable was stretched beyond so we put a new tensioner on and soon as I got the emergency brake fixed a week or so later this happened.
Old 04-08-2014, 10:12 PM
Rep:194
It is actually a big deal to adjust the rear brakes and parking cable together. You need the rear off the ground, and wheels off. It's all in the manual. You have the manual....right?
