Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 03-30-2014, 08:32 PM
BigHorn14's Avatar
BigHorn14 BigHorn14 is offline
Vehicle: 2014 ram 1500
Color: Deep Cherry Red
Rep:36
BigHorn14 is on a distinguished road
Exclamation First oil change question
When I changed my oil I drove it up on ramps like I did on other truck and did the usual steps. However when I went to transfer the old oil into the new oil containers to return I only ended up with 5 quarts. I put in the required 7 quarts and checked the dip stick and it looks good and the pressure and oil temps are good. So am I crazy or is this normal it seems like I put in 7 quarts I should get 7 out. I used Mobil 1 and a matching filter.
Old 03-30-2014, 08:42 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
iv'e been a quart low before but never two. maybe normal for a new engine, but that does seem like a lot. I would keep an eye on it. I check mine every other fill up.
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 03-30-2014, 08:56 PM
BigHorn14's Avatar
Rep:36
I definitely will from now on. I drove it and it drove normal and all seems ok but I thought it was a bit much as well
Old 03-30-2014, 09:07 PM
Fullmetal's Avatar
Fullmetal Fullmetal is offline
Vehicle: 2014 Ram 1500 QC
Color: Bright White Clearcoat
Fullmetal is on a distinguished road
Good info. What mileage did you change it at? I am looking to change mine at 3 months no even if I am still below 3000 miles for first oil change.
MODS: Mopar: Bright Pedal Kit, Hard Folding Tonneau Cover, Black Aluminum Running Boards, Molded Splash Guards, Door Sill Guards; Cabin Filter, Cravenspeed Stubby Antenna, EGR Black Matte In-Channel Window Visors, 3M 20% Tinted front windows, Xenon Licence bulbs, Dee Zee tailgate assist
Old 03-30-2014, 09:24 PM
BigHorn14's Avatar
Rep:36
I had 5000 miles, my oil life indicator said I still had 50% left. I have never went that long ever before, I based it solely on that indicator.
Old 03-30-2014, 09:35 PM
Rep:2657
First oil change can be done when you are comfortable doing it
Everyone has their own reasons for picking a certain mileage or time period
Old 03-31-2014, 09:56 AM
RaymondT RaymondT is offline
Vehicle: 2014 Dodge Ram
Color: Fire Red
Rep:12
RaymondT is on a distinguished road
I just did my first oil change last night at 7500km or 4700mi and it was a little bit down also.
No oil spilled on the steering thanks to sacrificing 5 terry rags (Costco). What a bitch place to put the filter! With the truck perfectly level, I put in 5 qts, ran it for 3 minutes checking for leaks. After 10 minutes, I added more eventually winding up with a total of 7 qts (6.5 liters). It was probably close to the add mark when I started.
2014 Ram Sport Fire Red 5.7/8-sp w/3.92
Old 03-31-2014, 12:10 PM
BigHorn14's Avatar
Rep:36
I found a little work around for the oil filter. I drive my truck on ramps and I can get easy access to the oil filter and slide a zip lock bag over the oil filter and unscrew it and the bag collects it all and keeps the truck nice and clean. Then take it all to auto store and recycle it.
Old 03-31-2014, 02:06 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:547
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Did my first change at 6600 miles. I was going to do it based on the indicator, but by that time I realized that I was on track for a 10,000 mile oil change and I'm just not comfortable with that especially since the factory fill is probably conventional. I now use full synthetic and change it at about 7000.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread-removed), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back.
Old 03-31-2014, 03:15 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
what is this oil life indicator you speak of?
