Old 03-31-2014, 09:55 AM
Golphin Golphin is offline
Vehicle: 2007 Ram 1500
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Golphin is on a distinguished road
Default Battery drain after a few days needs a boost
The issues I have are that the battery dies when the truck is not run for a few days also the wipers have not worked when the truck is cold but left for a couple of hours after it has run they work thought it was that they were frozen but not sure
The security light is now flashing but the truck is running fine
Let me know any ideas
And the battery is new
Old 03-31-2014, 06:10 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
The battery is new... That means that you probably have a draw on the battery from something when the key is off. You'll need to use an amp meter connected between your battery and your positive cable and see what the amp draw is. If's it's over .05 amps, then you have a problem. You'll need to start pulling fuses, one at a time, until the draw goes down to .05 or less. Once you've isolated what circuit the draw is on, you can fix it.
As far as the wipers go, sounds like your relay is bad.
Old 04-01-2014, 07:25 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Eric the car guy has a great video on this on his youtube channel. He explains how to do this properly with the do's and dont's so you wont wreck your meter while doing this.
Old 04-01-2014, 10:38 AM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
battery could have been bad new.. it's possible.
Old 04-02-2014, 01:39 PM
Rep:2929
Good thought! Always check the battery first.
