Superlift with Bilstein experience? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 04-02-2014, 12:08 AM
RAMNIT's Avatar
RAMNIT RAMNIT is offline
Vehicle: 2011 RAM 1500 CREW CAB
Trim Level: SLT 4X4
Color: BLUE
RAMNIT is on a distinguished road
Question Superlift with Bilstein experience?
Does anyone have experience with Superlift + Bilsteins?
I just ordered a 4" lift kit with bilstein struts from Superlift. I've read through the instructions a few times and the installation doesn't sound too intimidating (not my first lift)
does anyone have any experience with these kits?
anything I should look out for, not covered in the instructions?
Old 04-02-2014, 12:21 AM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
i don't ...but would sure like to see the end result when your done. do you have new wheels and tires going on too ? welcome to the forum
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 04-02-2014, 12:44 AM
RAMNIT's Avatar
Trim Level: SLT 4X4
Color: BLUE
Yep already have the wheels and tires. 35 x 12.5, 18R General AT. and HELO 18 x 9 -12 (4.5" backspace)
Old 07-22-2014, 08:31 PM
Tonka's Avatar
Tonka Tonka is offline
Vehicle: 2011 Ram 1500 Quad-Cab 4x4
Tonka is on a distinguished road
6" Superlift, maxed Bilsteins(Superlift uses them or a coil spacer in combination with the strut spacer to obtain the 6" lifted ride height.) 20x10 -24 offset XD Battalions with 37x12.50r20 Nitto Trail Grapplers(had to trim the bumper cover, air dam, and pinch weld at the rear of the front fender due to to much offset. I also had to reshape the fender liner where it bulges over the pinch weld area. In heindsight, I'd run less offset. -12 would have cleared without trimming.
Old 09-15-2014, 07:52 PM
mooseknuckle mooseknuckle is offline
mooseknuckle is on a distinguished road
I have this kit. I think rear coils are sprung to soft. Tons of body roll at hwy speeds with a load in bed. Called superlift they claim to have never heard of this problem and have not changed the rate on their progressive rear coils since introducing this lift. Maybe I got a bad batch of coils but unlikely. Plan on getting airbags for the rear coils since the back end will sag like crazy when towing or with weight in the back.
bilstein, lift kit, superlift, trail grappler, xd battalion
