Old 04-02-2014, 11:16 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Originally Posted by Boosted View Post
The point of my chart was to use as a simple reference point. Stock tire + gear ratio = rpm for reference. Take that and now look at the tire size you want to go to and find the gear ratio that will get you close to stock rpm's. This works regardless of what your final ratio is. Of course, your chart works too if you know all the ratio's to fill in the blanks with. You will find both ways will give you the same answer.
Bottom line is 3.55 gears with 37's and the truck will be a slug unless you are going downhill....
It would be correct for 4th gear which is a 1:1 ratio. But that's it really.... With ratios it makes a bigger difference as your gear ratio gets further away from 1. So well he might be off by 200 rpm in 4th gear he may be off by 300 rpm in 6th for example. So for a very basic comparison, yes a chest like that works. I'm just more OCD and anal than that... I prefer to see more information and have everything 100% correct. Just a personal preference I guess.
Originally Posted by draken View Post
how much does it cost to change gears?
In a 2012 and up you're looking at around $3500 to go to 4.56's. You need a front diff from a 2011, then both diffs need to be machined, then you'll need the ring and pinion, install kits, and labour.
Old 04-03-2014, 12:11 AM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
Still missing my point....
Actually the chart works perfectly to answer the simple question of "how big of a tire can i go with based on what gears I have", which if I am not mistaken the OP is basically asking.
Regardless of final drive ratio, overdrive, or whether you have a six speed or eight speed, the simple answer is to stay within 200 rpm's to what your vehicle came with from the factory. Anything beyond that and you will feel a drastic drop in power and fuel economy. The use of this chart is not a direct reflection of your actual RPM's, just merely a guide to show the difference you will experience with changes to gear ratio or tire size.
This is why most of us can get away with running a 35" tall tire without really feeling the loss whereas with a 37" tall tire, the loss is substantial.
Anyways, I'll get off my soapbox now. Bottom line to the OP, with 3.55 gears, I don't think you will be happy with 37's.
Old 04-03-2014, 01:00 AM
icallshotgun88 icallshotgun88 is offline
Vehicle: 2014 Ram 1500
Color: Black on black on black
icallshotgun88 is on a distinguished road
yeah, it sounds to me that its just not worth it to run 37"s…
there isn't much benefit to 37" tires other than it looks better.
its more expensive, more sluggish unless you change gears, even worse MPG and they may even be a tiny bit louder…
i REALLY wanted 37"s but i think my testosterone got the best of me…
I'm just gonna run 35"s and 20x10 wheels under a 6" lift..
HERES MY LAST QUESTION…
I'm going to get a 6" with Bilsteins…
if i set the Bilsteins at +2", will that extra lift make the 35"s look small?
cuz that like 8" lift on 35"s..
and i hate when tires look to small under a big lift..
Old 04-03-2014, 01:14 AM
Boosted's Avatar
Rep:219
I think yes, that would make the tires look small but that's just my opinion. Really it all boils down to what "look" you like.
Here's a suggestion that you could consider. If you want a little more tire (sidewall) but don't want to lose too much by going with a 37, look at a 325x60R20. Depending on brand, this tire will average about 35.5" tall whereas the typical 35x12.50(or 13.50)R20 will measure out to an average of 34.5". This will give you a little more sidewall for the "look" without getting too tall and hurting your power/fuel economy.
Old 04-03-2014, 02:22 AM
Rep:2067
Ya I get what you're saying as far as the basic function of the chart. Makes sense and yes it does basically answer the OP's question. Again it just boils down to the detail you want to go into. Personally I want to see exactly what RPM my truck would be at with each set up. But we'll leave it at that.
If you're going with 35's I'd set the Bilsteins at 1.4" to level the lift and call it a day. That way they won't look quite as small. Going with a 325/60/20 like Boosted suggested is also a good idea.
Old 04-03-2014, 02:38 AM
Boosted's Avatar
Rep:219
Yup, me too.
Old 04-08-2014, 02:50 PM
huntert's Avatar
huntert huntert is offline
Vehicle: 2009 dodge ram 1500 ST
Color: Austin Tan Pearl
Rep:16
huntert is on a distinguished road
I'm currently running 35s with just 3" level. I fills up the fender wells pretty nicely. Personally I wouldn't run the 6 inch lift if your gonna stick with 35s. The 4 inch and 35s looks like the best option. Once you go to the 6 inch I think you should run the 37s but then again if you want to do it right it's goin to cost you. Maybe you could try and do the 6 inch with 35s for a while then save up your money during those tires life and refers the truck. So that once those 35s are gone you can opt for a set of 37s and have the gears to back it up. Just my .02.
Westin black step bars, Diablo intune, 35x12.50x18 Nitto Trail Grapplers, 18x9 -12 offset MAYHEM CHAOS wheels. 2.5 inch dual exhaust with a custom made x-pipe before dual dynomax race bullets, topped off with rectangle tips.
Old 04-18-2014, 01:42 AM
Baldielox's Avatar
Baldielox Baldielox is offline
Vehicle: 2012 Ram 1500 4x4
Trim Level: Laramie Lonestar
Rep:21
Baldielox is on a distinguished road
6" lift + Bilstiens in the front with 35x12.50's
Old 04-20-2014, 09:53 AM
Ramguy45's Avatar
Ramguy45 Ramguy45 is offline
Vehicle: 2011 Dodge Ram
Rep:15
Ramguy45 is on a distinguished road
Awesome truck! Mine is about to look very similar as I have a red one too and I have also been debating running 35's or 37's, but I went with 325/65/18's. Can you tell me how much clearance you have from the top of your tire to the bottom middle of your fender? I have been worried I will have to much. I have a chevy with a 6 inch lift and 315's I had 11 1/2 inches of clearance and I thought it looked perfect. What are your bilstein's set at? Everyone seemed to be out so I went with rancho 2.25's instead. I can't wait to see how it looks!
Old 04-20-2014, 10:07 AM
Ramguy45's Avatar
Rep:15
I went with a 325 for this reason, but looking online at charts I keep seeing that a 325 is really only 34.6 and a 35 measures 35. Can anyone verify what is correct because I am confused.
