Fox 2.0 Shock Review - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 04-02-2014, 12:03 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
Default Fox 2.0 Shock Review
I promised a few people I would review these once I had them in the dirt.
Well. I not only got them off the road but I towed my travel trailer in some of the worst wind I've ever been in. All I can do is rave about them. They really roll significantly less in the wind than the stock shocks. The wind really wore me out and I'm really glad to have had them on the truck while towing. Normally I flinch crossing railroad tracks with the trailer on but these things took it in stride.
Off road these things are great. They are so beefy they just soak up everything even at speed. Love these things.
Old 04-02-2014, 12:38 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Good to hear! I have a set of Fox shocks coming with my BDS lift for my truck, looking forward to getting them on there and see how they ride on a 3500. They also look pretty sick!
Old 04-02-2014, 01:57 PM
h2oman's Avatar
Rep:418
You're gonna love them on your beast.
Old 04-03-2014, 11:55 PM
RAM357's Avatar
RAM357 RAM357 is offline
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
I agree.
What I love about the Fox shocks is the margin of control and safety they bring to the table. I commute 100 kms a day and 35 of those are secondary hwy and dirt. Plenty of washboard these days and I tend to run between 100-180 km/h and no matter the speed, or terrain the truck feels predictable and stable.
I find the high frequency bumps are felt more than the slower (lower frequency) stuff. Those it undulates over nicely, but the faster stuff you feel more. And by faster I don't mean speed, I mean the frequency which the shocks cycle.
But no matter the feel, you're always in control and with a total of 8" lift and running heavier 37's this is pretty important at certain speeds.
Cheers,
Var
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau* Iron Bull Fr. bumper with custom Line-X coating* Lumens HID low beams
Old 04-04-2014, 10:20 PM
huntert's Avatar
huntert huntert is offline
Vehicle: 2009 dodge ram 1500 ST
Color: Austin Tan Pearl
Rep:16
huntert is on a distinguished road
Would you guys recommend these over the 5100s for a set up that's 35s and leveled? No lift. And also are they really worth the money over the 5100s. Either way I go I'm buying for all 4 corners.
Westin black step bars, Diablo intune, 35x12.50x18 Nitto Trail Grapplers, 18x9 -12 offset MAYHEM CHAOS wheels. 2.5 inch dual exhaust with a custom made x-pipe before dual dynomax race bullets, topped off with rectangle tips.
Old 04-05-2014, 12:20 AM
Boosted's Avatar
Boosted Boosted is offline
Vehicle: 2018 Ram 2500
Rep:219
You cant run these or the Bilsteins on the front of a "leveled" 4th gen unless you remove the spacer (I'm assuming) that was used to level it to begin with. If that's what you mean, then yes the Fox Shox are better than the Bilsteins.
Old 04-05-2014, 12:39 AM
huntert's Avatar
Rep:16
Yeah have a HBS 3" inch I will be taking off. It was just a cheap way to run my 35s. I was assuming the Fox Shox are adjustable like the 5100s?
Old 04-05-2014, 09:22 AM
Boosted's Avatar
Rep:219
They are adjustable but the way they adjust is different from the bilsteins. The shock body is threaded and you adjust the ride height using a spanner wrench (which I recommend you purchase at the same time) to lift or lower. Bilsteins use a circlip in a groove which determines where the spring perch will sit. Multiple grooves for different height.
Old 04-05-2014, 11:48 AM
h2oman's Avatar
Rep:418
What Boosted said.
Old 04-05-2014, 12:57 PM
RAM357's Avatar
Rep:580
Here are the spanner wrenches for adjusting the Fox coil-overs:
Here is a good shot of the top of the coil-over showing the adjustment rings:
And here is a Fox 2.5 coil-over on a tacoma application:
Ignore the numbers .. I grabbed this photo off of google images quickly. But you can see that unlike the Bilsteins, the Fox coil-overs offer nearly infinite adjustment .Not only up and down, but in relation to each other .. if your truck was heavier on one side , you could tweak that coil-over so it lifted the truck on only that side by a fraction of an inch. Bilsteins offer a small handful of adustments only.
And you could tweak the Fox's on the fly, whereas you'd have to remove the Bilsteins to make an adjustment.
Also my Fox coil-overs are entirely rebuild-able. I could change out the oil for a different weight, or the coil, or the valving etc etc. LOT's of custom potential, as well as the simple ability to overhaul the equipment instead of shelling out thousands to get all new shocks.
Var
