Old 04-02-2014, 07:37 PM
whiteknight312 whiteknight312 is offline
Vehicle: 2012 dodge Ram Bighorn
Trim Level: big horn 4x4
whiteknight312 is on a distinguished road
Default Oil filter removal tool for factory 5.7 mopar filter
hey guys, looking for a metal factory fit oem filter removal tool with the 3/8" socket end. can you buy them from the parts place or a supplier for OEM? it has to be metal and fit direct on without slipping. I have a plastic one that Sucks big time and wont even go onto it. mopar makes a different shape end. but its so hard to get a hand on it and turn, impossible!
thanks for your help
I have a 2012 Ram 5.7 hemi. dont know if anything changes with the filters
Chris
Old 04-02-2014, 08:03 PM
MOPAR70's Avatar
MOPAR70 MOPAR70 is offline
Vehicle: 2007 Ram 1500 4x4
Color: Mineral Gray Metallic
MOPAR70 is on a distinguished road
I wold purchase an oil filter wrench, available at any auto parts store. The filter on the trucks with 5.7s are in a particular place but it can be accessed with a wrench.
Old 04-02-2014, 08:12 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
I got a metal one from Partsource. You might not have those in the US of A. Maybe this one from Autozone is the same..
http://www.autozone.com/autozone/acc...ier=153159_0_0_
Simon
Old 04-02-2014, 08:31 PM
the ones i have seen dont fit the head of the mopar filter. the aftermarket heads seem to be ok. so I thought use a factory one that will not slip off
Old 04-02-2014, 09:57 PM
LowUFO's Avatar
Rep:1105
Take a filter into the stores. That's what I did and got lucky first try. But I don't use the Mopar one. I use the Napa Gold filters. But it worked to take that first filter off no problem and subsequently the Napas ever since..
Simon
Old 04-03-2014, 12:59 AM
Trim Level: sport
Color: green
Rep:643
you could always use a white K&N oil filter with the nut on the end. easy to get off.
Old 04-03-2014, 01:33 PM
Dodge cranked the old one on. I had it changed "free" first time. Now, I thought I would be able to get it off this time. NO GO.
so, I either try to jam a screw driver into the side and hammer it off. Ive done that before, but there is little room to do even that. I really need a factory Cap tool that will turn that old bugger off.
After than, I will oil the seal first and hand tighten on (not cranking it on!!!)
I do like K&N filters though. that nut saved me in the past and great filters
Old 04-03-2014, 01:42 PM
Trim Level: sport
Color: green
Rep:643
i find that hand tight is not enough on the hemi. i had a leak a few times with just a normal "hand tight". now after i hand tight, i do a little more than a 1/4 turn with a wrench on the K&N filter. that is actually why i started using the K&N.
Old 04-03-2014, 05:39 PM
303Ram's Avatar
303Ram 303Ram is offline
Trim Level: Crew Cab 4X4 Express
Rep:15
303Ram is on a distinguished road
Don't forget to buy some aluminum foil while your out. A trick my I picked up from my Pops years ago. Tin foil oil slide. That is unless you want oil all over EVERYTHING.
Mods in order of Progression
In Cabin Air Filter, Bilstein 5100 Series @ 2.1, Debadged, Moe's 87mm Ported TB, BT Catch Can, Weathertech DigitalFit FloorLiners, Dball2 w/ CHTHD1 T-Harness, S&B Cold Air Intake
Awaiting Spousal Approval
Cat Back Exhaust or True Duals
Old 04-03-2014, 06:19 PM
Rep:2616
I would think that a tool like this is what you need
most Mopar oil filters look like this
