Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 04-03-2014, 01:59 AM
03Ramtruck 03Ramtruck is offline
Vehicle: 2003 Dodge Ram
03Ramtruck is on a distinguished road
Default Electrical problem
Hi,
I have a 2003 Dodge Ram 1500 and for some reason, my left side tail light doesn't work. In fact, I do not get power on the running wire for trailer connector, left tail light and left license plate light. Brake, reverse and turning lights work. I checked the wire and from what I've seen, there is nothing wrong with it. Fuses are good too. Does anyone have any idea what might be wrong? Thank you
Old 04-03-2014, 02:06 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Hi, and welcome to the Ram ForumZ. I invite you to stop by the Newbie Check In section and introduce yourself so other members can give you a proper howdoyado.
As far as your electrical problem, my first guess would be that you have a bad ground. Check the ground on your tails and license plate light. Secondly, swap the actual light board with the right side and see if it follows. It may be a bad circuit board. If that doesn't pan out, then get an electrical schematic for your truck and start tracing the wires back to the IPM (fuse box).
Any more questions, don't hesitate to ask and keep us updated on the progress.
Old 04-03-2014, 12:20 PM
I already switched the light board. If it were the ground, I'd have issues with the brake, reverse and blinker too since it's the same ground. I can't find the schematics for my truck either. I thought maybe some relay was not working properly but I don't know which one to look for. I also tracked the wire to the fuse box and as it comes out of the fuse box, I checked and it does have power there so somewhere between the fuse box and the tail lights is my problem but I can't figure what.
Old 04-03-2014, 11:24 PM
Rep:2968
Then you have a break in the wire. You need to get a manual with an electrical schematic and see what circuit they are on.
Old 04-04-2014, 08:25 AM
nosu13 nosu13 is offline
Vehicle: 2003 Dodge Ram 1500
Rep:22
nosu13 is on a distinguished road
i have had a similiar problem I solved it buy changing the entire strip in the rear which encompasses all bulbs. Havent had an issue since.
