New lift, wheels and tires, and the shop screwed it up - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-05-2014, 11:25 PM
Baldielox's Avatar
Baldielox Baldielox is offline
Vehicle: 2012 Ram 1500 4x4
Trim Level: Laramie Lonestar
Rep:21
Baldielox is on a distinguished road
Procomp 6", 35x 12.50, Bilstiens, 18x9 5 bs. no idea what the bilstiens are set at they didn't tell me.
Old 04-05-2014, 11:45 PM
Baldielox's Avatar
Rep:21
Procomp lift 18x9 wheels withe 5 bs
Old 04-06-2014, 12:20 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
Get under and take a look. I'm guessing they are set at max height-2.8" (circlip in top groove.) when they should be down around the second (0.7") or third (1.4") groove from the bottom depending on how much rake you want.
285/65/20 BFG TA KO2s, Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 04-06-2014, 01:05 AM
RAM357's Avatar
RAM357 RAM357 is offline
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Taking the flares off was a smart move. Now you need to return to have that front dropped. Once you do that it should look pretty nice!
Bring the shop manager outside to compare the picture you originally showed them to your truck. The fix should be no expense to you!
Good luck & keep us posted!
Var
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau* Iron Bull Fr. bumper with custom Line-X coating* Lumens HID low beams
Old 04-06-2014, 01:12 PM
Baldielox's Avatar
Rep:21
Looks like the Bilstiens are set on the 4th ring from the bottom.
Old 04-06-2014, 01:34 PM
RAM357's Avatar
Rep:580
It has to go back ASAP. Have the knuckleheads fix it by dropping the coil bucket on the Bilsteins. Tell them if you want level or ass-high stance so they get it right.
This type of thing is infuriating. I have a great shop, with trustworthy mechanics but I'll still sit in the lobby for several hours on some jobs because I know things come up that need my input and eyes on the problem.
I would have just walked away, not paid a dime and demanded they make it right immediately. Surely the installer isn't so daft that he thinks that looks OK at any level. WTH??
Brutal .. sorry you have to deal with this BS.
Var
Old 04-06-2014, 07:25 PM
LowUFO's Avatar
Rep:1125
Yeah, measure the front from the ground to the top of the arch and then do the same for the rear. The front should sit half inch lower than the rear to give the optical illusion of level.
The bottom groove is zero lift, the next is 0.7" higher than stock, the next is 1.4", the next is 2.1" and the top is 2.8".
If the front ends up measuring the same as the rear with the Bilsteins set at the lowest setting, it will still appear to be slightly nose high. So if it comes to that, get a half inch coil spacer for the rear.
Old 04-07-2014, 12:39 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Snap a picture of the front suspension like the one below and post it up. I'd like to see the Bilsteins and how they were put together because I still think they have the lower spring seat flipped. Especially if you could tell that it was on the 4th groove. If they were put together correctly you shouldn't be able to see that.
If you want to run pocket flares and have your tires be flush with them you need 18x10 -12 offset wheels with the 35x12.5 tire.
Old 04-07-2014, 06:01 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
I was going to suggest the same thing. I think the seats are upside down. You shouldn't even really be able to tell what groove the clip is in, cause the Spring seat (if installed correctly) pretty much covers it.
Keep us posted!
Sponsored by:
Old 04-07-2014, 07:00 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
subscribed....
