Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-05-2014, 04:38 PM
Aldo462 Aldo462 is offline
Vehicle: 2010 Dodge Ram1500
Aldo462 is on a distinguished road
Default Draining the F**king Radiator
I beleive I have found the petcock on my 2010 Dodge Ram 1500 4.7
I am looking to do a Cooling system flush with a thermostat change. This petcock does not appear to be your typical one. does she screw off? pull off There seems to be a Hex key fitting inside of it. I really want to prevent any expensive weekend warrior mistakes. my automotive skills are only up til the 90's. So I have a Chiltons book for my rig but it does not discuss the draining of the radiator......Really whats the big secret here!!!!!:4-dontknow:
Old 04-05-2014, 04:49 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I just pulled a lower radiator hose off. The dealer might be able to punch up a drawing of that drain plug for you.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 220,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-05-2014, 10:23 PM
I push the skinny pedal
Rep:3283
I use a socket that fits over the fitting, there are 2 tabs on the side of the plug that get squeezed together when you put a socket onto it. You only turn the petcock until the fluid starts coming out slowly, you generally have one full revolution before the thing will fall out on its own and you lose the ability to direct it down through the drain, it will start spraying out of the hole you just created.
Kurtis
Old 07-08-2014, 05:23 PM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport lowered 4X4
Rep:488
Just did my thermostat,and thanks to Kurtis i used a socket.
Found a 5/8" or 16mm deep socket worked good to grab the tabs on the petcock.
Thanks for the heads up Kurtis.
Rick
