Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Place your Ad Here!
Old 04-10-2014, 07:37 AM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport lowered 4X4
Rep:488
Pqia i thought was funded by petroleum companies.
Makes you wonder how good they are,if they don't have any info on Redline,that seems a little suspicious.
I'll check out your other link later,but here's one for you to check out to.
There's a few others,but i'll have to dig for them,and most of them rate Mobil 1 lower then Amsoil or Redline.
Mobil 1's base stock is a grade lower then either Amsoil or Redline as far as i've read,and i've done a fair bit of reading on oils in the last year
http://www.bobistheoilguy.com/puttin...nto-viscosity/
Old 04-11-2014, 11:41 AM
ghorn ghorn is offline
Vehicle: 2012 Ram 4X4 Crew Cab Rambox
Trim Level: Custom HD Tradesman
Rep:74
ghorn will become famous soon enough
That link is not germane to the subject. It describes viscosity only.
Bob is the oil guy is a familiar site to me. I like it, but it has never answered the question we're discussing to my knowlege.
Old 05-25-2014, 04:14 PM
UnleashedBeast UnleashedBeast is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: TRX
Color: Inferno Red Crystal
UnleashedBeast is on a distinguished road
The PQIA is an independent testing organization, non-biased. You can take their test results to the bank.
Originally Posted by ghorn View Post
They provide tables of comparison between various oils, and their Mobil 1 chart indicates better NOACK testing results (volatility) for Mobil 1 than Amsoil . They don't list Redline I don't believe.
Here's a link that may prove informative: http://www.pqiamerica.com/March2013P...sallfinal.html
The Amsoil OE lubricant tested in the link above is Amsoil's cheapest lubricant, and is known to be cheap group III hydrocraked petroleum. It compares to the current formulation of Mobil 1. Amsoil sells OE for less than $5.00 per quart to preferred customers (online members), what you should pay for cheap base oil.
However, Amsoil Signature Series 5W-20 has a NOACK of 5.5%, almost 50% lower than anything Mobil 1 formulates. Why, because it's a true PAO/Ester synthetic base oil, not cheap hydrocracked "highly refined" petroleum.
Amsoil Signature Series 5W-30 - 6.9%
Amsoil Signature Series 10W-30 - 5.3%
Want to know what people should fear. The fact that big oil companies omit this specification on all of their spec sheets. Why, because they are hiding the truth. This one spec alone reveals base oil used in the formulation. You are not getting a true "fully" synthetic base oil, yet still paying the price for it.
Old 06-21-2014, 11:49 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
Maybe give us a link to these other labs Ghorn.
I've never seen a lab test that rates Mobil1 higher then Amsoil or Redline,so i'd like to read your lab test findings.
Same here. I would also like to read that lab test.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 06-21-2014, 12:01 PM
cemeflybyu cemeflybyu is offline
Vehicle: 2006 Ram Big Horn
Trim Level: Big Horn SLT
cemeflybyu is on a distinguished road
Subscribing...good question..
Old 01-16-2015, 10:27 AM
Color: White/Gold
Rep:487
You will be safe using any oil that meets Chrysler MS-6395 specification. There are very little differences in the newest high tech oils used in today's vehicles. Where it would make the biggest difference is if you were driving a race car or using your truck under extreme conditions. Extreme temperatures are hard on a racing engine but for factory cars and truck you more than safe using conventional oils.
Having said that, There is a lot of hype about oils and which ones to use. The manufacturer depend on consumer ignorance when it come to which oil to use.
I don't put a lot of miles on a new vehicle. Nor do I put my truck to the test by hauling and towing heavy loads in extreme weather or dirty conditions. I have been using Amsoil products for several years now and have only done so because of the marginal differences and advantage Amsoil has over other oil.
I've ridden motorcycles for 49 years. About 35 years ago I switched to synthetic blend oil and had samples of used oil annualized by Blackstone Laboratories. Only because of the marginal differences did I switch to using Amsoil full synthetic oil.
Old 02-09-2015, 12:23 PM
hotkarl's Avatar
hotkarl hotkarl is offline
Vehicle: 2002 Dodge Ram SLT QC 4X4
Color: Silver, PB2
hotkarl is on a distinguished road
I use Mobil 1 full synthetic with a Mopar filter on all of my vehicles. 5w for the Ram 4.7
2011 Ram Big Horn...RIP(thanks to Hurricane Sandy)
PS2 Bright silver, Hemi Quad cab, 3:92's, most of the other bells and whistles.
1998 Dodge Durango 5.2 4X4...The family truckster!
Old 02-11-2015, 12:51 AM
striker2237's Avatar
striker2237 striker2237 is offline
Vehicle: 2003 Ram Laramie 4x4 3.55 LSD
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver
Rep:167
striker2237 has a spectacular aura aboutstriker2237 has a spectacular aura about
I'm using Amsoil 0W20 signature series , four years running with a UAP Napa gold filter. Bully's performance sells it at an awesome price. Yes 0W20 is perfectly fine and equivalent to 5W20.
Fair warning the lower starting viscosity provides LESS startup wear protection than a heaver one (5W20) and is the reason I run 10W30 in my engine instead of 5W30 or 0W30
Mods: OEM tonneau cover+bug deflector+bedliner+floormats+hitch light+fuel door, Stubby antenna, 900CA AGM battery, Silverstar lights, Front window tint, Cabin filter, Bilstein 4600s, Kicker stage 1, Rear wheel liners, Mopar valve covers+breather, Pacesetter wrapped headers, Custom midpipe, Magnaflow X-pipe+custom axleback, SSBC front brakes+Powerstop rear, Moog front suspension+hubs, Maval custom rack, Borgeson steering shaft, Stainless steel brake lines, Hellwig front/rear sway bars, Poly bushings, Custom springs, Hydroboost
Old 02-11-2015, 03:47 PM
Rep:488
How do you figure that Striker.
Thinner oil pumps faster,especially at -20.
Thinner oil also makes starting the engine easier.
It's thick oil that makes turning the engine over harder.
The oil pump creates a pile of drag,and it gets worse the thicker the oil,and the colder the temps.
Thick oil will also cavitate the pump at cold temps,that's where the pump will run empty,till the oil slowly flows into it
All oils drain off when you shut the engine off warm,if that's what your basing your advice on
So clue us into to your theory
Find a freezer that is at -20,and try poring the differant viscosities of oil.
10w-30 doesn't pore worth shit at those temps compared to 5W-30 or 0W-20
